A guy with a truck
Gringoloco's Spring Cleaning Sale
UPDATES:
1) Crossmember *SOLD* 2) Shocks *SOLD* 3) Cups *SOLD* 4) U-bolts 1" longer set *SOLD* New stock length *SOLD* 5) Tailgate Trim *SOLD* 6) Flip Kit *SOLD* 7) LS1 Mounts *SOLD* ___________________________________________ ___________________________________________ 1) 2WD automatic transmission crossmember. Powdercoated semi-gloss black. Two small scratches on mounting pad are not visible when installed. SOLD
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-19-2008 at 03:10 AM. Reason: Update |
A guy with a truck
Re: Gringoloco's Spring Cleaning Sale
2) Pair of Explorer 'Toxic' drop shocks. ~18" extended, 11" collapsed. These are what Summit Racing sends for a 3" to 5" drop on the rear of a coil spring truck. Little dirty but still work perfectly. I'd still be using them if both my trucks weren't bagged...
SOLD
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-16-2008 at 02:29 AM. |
A guy with a truck
3) Pair of ***************** lower bag cups. These bolt to the bottom of air springs to allow them to sit in the front lower control arm spring pocket. They have been trimmed to 1" total height and powdercoated semi-gloss black.
$10 plus shipping
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Can you get me a shipping cost to 33024 on the shocks? Thanks, Harry
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
A guy with a truck
4) Coil spring rear axle u-bolts. I have three pairs of these. Two are stock length and one pair are 1" longer.
Left: I used them for mock up, but never torqued them down. They have a little overspray and light surface rust. $15 plus shipping Middle: Brand new stock length $20 plus shipping Right: Brand new 1" longer than stock $25 plus shipping Spray-Bomb has dibs on one set.
A guy with a truck
UPS ground is $12.86 on their online estimator.
Sent you a PM
A guy with a truck
5) Upper tailgate trim. Good and straight, no dings. Would polish out very nicely. Missing one clip.
SOLD
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-16-2008 at 02:30 AM. |
A guy with a truck
6) DJM rear axle flip kit. This kit will place the rear axle on top of the rear leaf springs giving you around 5.5" of drop. I removed it from my truck when I converted from leaves to coils.
SOLD
buffle
Flip kit to zip 64055, thanx buffle
A guy with a truck
7) Early Classic (ECE) GenIII motor mount kit. This will allow you to bolt a late model Vortec 4.8, 5.3, 6.0 or an LS1, LS2 etc. into your truck's engine bay. I went to a Dropmember setup, so I have no use for it.
SOLD
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-16-2008 at 02:31 AM. |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-11-2008 at 07:55 PM. |
#13 |
![]() Join Date: Jul 2001
put in line pending shipping on engine mounts. Also I have 92 5.7 will these work?
11 Surbaban 70 C 10 still in progress |
#14 |
A guy with a truck
These are not needed. You should be able to use your stock mounts. These are intended for the '98-up motors...
#15 |
![]() Join Date: Jan 2008
I'll take it pending shipping to North Carolina 28540 please.
#16 | |
The LuvShack Garage
Shipping to 38313
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#17 |
One of the First
![]() Join Date: Jan 2000
Axle Flip kit, shipping to 32092
#18 |
How much to ship the tailgate trim to 02302?
#19 |
next on the tailgate trim shipped 55330
#20 |
put me in line for the mounts pending shipping
#21 |
10/30/19
I will take the 1" longer u bolts if no one has a claim on them and pending shipping to 66067.
Fight the good fight, finish the race, keep the faith Last edited by kingsolver72; 04-12-2008 at 02:47 AM. |
#22 |
#23 |
C10 Club Tennessee
shipping on bag cups and engine mounts to 37188
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
#24 |
i will take the motor mounts and the shocks if they are still available. let me know where i can send the payment.
#25 | |
A guy with a truck
UPS ground $14.38
Guys here have said they work with 73-87 arms. I ended up using 1.5" cups for peace of mind... They will go in a Flat Rate envelope -$5 UPS Ground $17.44 They will go in a tube. Call it $10 for materials and shipping. Same deal if thealien passes... UPS Ground $22.17 to 91910 Quote:
If the others pass, I'll throw the cups in the same box. UPS Ground $17.04 Shocks are pending sale to myoldchevytruck and there are a few ahead of you for the mounts. I'll let you know when/if it gets to you...
