Old 10-31-2002, 08:05 PM   #1
BaggedC10
Under construction!
BaggedC10's Avatar
Question Question for Mike...........
Hey, I will soon be replacing my factory dual tanks with a fuel cell. I am going to install an aluminum 15-gallon unit from Jegs with a GM sending unit in the bed. Will I be able to install SS flexible braided line from the current three frame rail mounted ones? How should I go about doing this? Any suggestions would be greatly appreciated!
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 10-31-2002, 08:57 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
They make a fitting in the AN stuff you can adapt the braided hose to hard line. But, I would run hard line everywhere I could. It will last longer you won't have to worry about leaks. After all, braided hose is rubber on the inside.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 10-31-2002, 10:46 PM   #3
BaggedC10
Under construction!
BaggedC10's Avatar
Thanks for the reply! I'm going to mount the fuell cell directly behind the front bed panel---So, I won't be installing too much of this line.
