04-12-2008, 01:51 AM | #1 |
Need alternator wiring help Please.
Hey all,
I need some assistance with a wiring problem. I needed to replace the internal regulated 3 wire alternator with a new one. the one I got from summit has a different plug on it. i figured no problem, I will change out the plug and wire it up the same way. I went out there this morning and the car was dead. Obviously it doesn't wire the same. Can you take a look and tell me where I went wrong. The flatter white plug is what was originally on the car, with the flatter alternator. The squarer plug is what is on there now. Where did the wiring go wrong? The battery was perfect before changing the alternator. The bearing was going out on the previous alternator, that is why it was replaced, It was still charging fine. Thanks in advance.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
04-12-2008, 02:10 AM | #2 |
Hollister Road Co.
Re: Need alternator wiring help Please.
The square plug ALT is 10DN for an external regulated ALT. You got the wrong ALT. You want a 10SI model ALT for the flat plug. It is internally regulated.
