I just recived a new black houndstooth bench seat cover for my 71.
I've been searching here with no luck for a forum on - "How To rebuild/reupholster a stock bench seat"? Who here has done it. And what tricks to help in the process. The foam in my bench is still firm and in great shape. other than hog ring plyer's and 150 hog rings what's needed to do a great job?
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
Re: Bench seat cover reupholstery
I just bought a "fix up" kit or what ever its called from LMC with new upper foam, and built up the lower piece using tape/foam from micheals. As far as re-upholstery, I found a custom shop in Vegas that did a pretty good job on it for about $150 bucks using all new vynil/fabric.
Sorry I couldnt be more help. Upholstery is one of the few things that I still leave up to someone else.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
Gettin By on Gettin By
Use spray glue. Turn your new cover inside out. that helps alot too. Some good 3m spray glue. Start at the top and slowly work your way to the bottom. Or front to back. Its not hard, just takes a while to get a nice look with no waves or folds.
a hair dryer comes in handy to help strech and fit the covers in the corners and sides
Tot Roddin'
Check with Classic Parts of America, they offer the cover and I think all the rest of the supplies.
I think would be a great candidate for a new FAQ... especially since I'm picking up my original '71 bench this weekend. ![]()
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
ttt - Anybody?
spray glue really isn't necessary. i've now done a few of these repop covers with great results. set it in the sun and look out for sharp edges on your frame. sometimes good to slip some chipboard on the sharp edge.
I also think Brothers has a tech write-up on their website. try here: http://www.brotherstrucks.com/techar...20INSTALLATION
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ Last edited by cstanley; 04-15-2008 at 09:07 PM. |
THANKS, That's is exactly the type of directions I was looking for!
Moderator
![]() Join Date: May 2007
Let the cover sit in the sun for a while and that helps smooth out the creases before you install it.
![]() Join Date: Feb 2004
Hey,
You know that were gonna want to see pics of the process when your done with yours. Keep that digital camera close
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
leddzepp is right, if you let the cover sit in the hot sun for a while it will certainly go on a lot easier.
Chad, Take good notes on this, I'll be doing my seat in a couple weeks!
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
I'll take lots of pictures and take notes as i go!
Then do a write up from what I learned for frequently asked questions!
#13 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
On the Blazer forum.
http://67-72chevytrucks.com/vboard/s...d.php?t=287185 And here for ALL the pic's. http://public.fotki.com/blazbk/blaze...g_my_2_buck-1/
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 04-16-2008 at 08:43 PM. |
