68 GMC front cip to 72 chevy cab
I found a decent 68 GMC front clip that I am thinking of installing onto a 72 chevy cab. I am hoping all will bolt right on or are there some surprises I dont know about. My 72 has air, so will the core support on the 68 GMC be the same as the 72. Or can I just swap out core support? Thanks
its all about the +6 inches
Re: 68 GMC front cip to 72 chevy cab
You'll need the whole front clip, core support, fenders, hood, obviously the grill too. it'll all bolt right on no problem.
The GMC has 4-lights, if you are using the grill and all it direct bolt up, if you want single headlight with a 67-8 chev grill the 72 will work, just pop the headlight stand off, and get some 67-8 buckets (67-72 Chev grill is identical except the 69-72 has a bracket {for the headlight} to push it out further) knock off the spot welds and you have a 67-8 chev grill.
I was a second too late, but same answer! Last edited by 70rs/ss; 04-12-2008 at 11:19 PM. |
I will be looking for a 67-68 chevy grill and not use the GMC. Its not in bad shape but I prefer the chevy.
