Old 04-13-2008, 03:56 AM   #1
Fraser Beatty
Fraser Beatty's Avatar
Leaf Springs Help
I just bought an 83 Chevy C10. It appears that someone has removed a rear leaf spring or two from either side. How many were in there from the factory? I've never done rear leaf springs before. What is the process in removal/reinstallation? Thanks so much for the help.
1961 GMC 930- SOLD
1979 GMC C35 Single Wheel Camper Special- SOLD
1980 GMC C25 Camper Special- SOLD
1983 Chevrolet C10- SOLD
1983 Chevrolet Camaro- SOLD
1985 GMC C1500 (Dad's truck)
1985 GMC C3500 Crew Cab Dually- TRADED FOR 61 GMC
1997 Dodge Ram 1500 V6 Shortbox- Daily Driver
Fraser Beatty is offline   Reply With Quote
Old 04-14-2008, 09:03 PM   #2
Fraser Beatty
Re: Leaf Springs Help
Anybody?
1961 GMC 930- SOLD
Old 04-14-2008, 09:47 PM   #3
bedsled71
bedsled71's Avatar
im not sure how many there were but you need to be carful when removing them, you need to get the tension off the string before you unbolt becuase there is alot of tension there
bedsled71 is offline   Reply With Quote
Old 04-14-2008, 10:46 PM   #4
Fraser Beatty
Thanks for the advice. Can anyone tell me how many springs there are supposed to be?
1961 GMC 930- SOLD
Old 04-14-2008, 11:14 PM   #5
bedsled71
bedsled71's Avatar
i think there are 5 total. 4 then the overload.. how many do you have?
Old 04-15-2008, 12:28 AM   #6
Fraser Beatty
There are only 2 in there on each side at the moment...the PO said he has been driving the truck like that ever since he bought it with no problems, but I want to get the correct amount in there as soon as possible.
1961 GMC 930- SOLD
Old 04-15-2008, 12:37 AM   #7
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
However many you had from the factory just depends on how it was equipped from the factory. If you plan on doing any towing or putting anything in your bed, you should probably get a couple more leafs in there. It's pretty straight forward. Drop your axle from the leafs and you can just pull the bolts on either end of the leaf, and it will drop out. There should be a bolt running through the center of all of the leafs holding them all together. If you pull your leaf pack, I always think it's a good idea to replace this bolt with a new grade 8 bolt. If you weren't so far north I could just give ya all my leftover springs that I've pulled.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 04-15-2008, 12:48 AM   #8
Fraser Beatty
I've got a couple kicking around and there's bound to be a few in the local junkyards, so it shouldn't be a problem finding any. I've just never done this before, so I was looking for some advice on how to put em in.
1961 GMC 930- SOLD
