STOLEN
![]() Join Date: Jun 2006
Radio or Speaker problem?
When I turn the original AM radio on in the truck at full blast on a quiet night I can just barely hear it. Do you think the radio has a problem or the speaker has gone bad?
P.S. I have good hearing ![]()
In Search Of |
Re: Radio or Speaker problem?
try cleaning the connection and ground for improved volume
Foolish Mortal
id wager on a blown speaker, if the radio is still pushing sound even to the smallest extent its probly not bad unless u broke some stuff in the radio dukes of hazzarding ur truck reaently
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
The antenna can cause low volume also. If you have a known good antenna, try plugging it in before pulling the radio.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Active Member
![]() Join Date: Jul 2007
Has it ever worked? Here's what I did would do.
First check it with another speaker and if volume is still low, take the radio out and give the volume knob variable resistor a good cleaning with elecro clean. One last thing is to make sure the antenna has a good clean connection and adjust the pod under the tuner knob for maximum reception... |
in my assembly instruction book it give a procedure for peaking the antenna trimmer
1. set antenna mast at a height of 31+/- 1.0 inches 2. set volume control knob at max volume 3.tume radio to a signal at or near 1400 kc 4. adjust antenna trimmer screw(+/-2 screw rotation) until maximum volume is received 5. turn receiver off try this I hope this will help
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
STOLEN
By process of elimination, bad speaker and antenna. Now that I have it all working, it's ime to put it back together. Thanks for the help everyone.
In Search Of |
Active Member
67CHIP72, good to hear you found your problem... Now, when you get it all fixed you can help me out. See if you have an AM station beyond 1510 or higher in your area and see if you can get it. I can't seem to get a 1620 station that we have in our area....
Check in here to see if you do... http://www.radio-locator.com/ |
Active Member
I did a search on your city and actually you do... Its and Asian station 1650, but that's okay. I just need to know if you can get the station in.... Appreciate the help.
#11 | |
STOLEN
In Search Of |
Active Member
You have these staions that may be available depending on your reception.
KMPC 1540 AM 32.6 mi. Los Angeles, CA Asian KBLA 1580 AM 35.2 mi. Santa Monica, CA Spanish KAHZ 1600 AM 27.4 mi. Pomona, CA Asian KFOX 1650 AM 34.9 mi. Torrance, CA Asian If you can't get any of these, even faintly, I think that tells me that it's our old radios. Maybe they can't go beyond the low 1500's. Thanks. |
