68 frame same as 67?
I'm working on tearing down my 68 sb and have found a 67 frame that has been sandblasted and painted chassis black. The 67 frame has a automatic trans crossmember already in it, my 68 does not. This was a state dept of highway truck and might be 3/4 ton, mine is half ton. Is there a difference or can I use this frame without trouble? My frame is pretty rusty and this one is only selling for $300 rolling chassis. I guess my question is are the frames the same?
Questionable
Re: 68 frame same as 67?
'67 "supposedly" doesn't have the dimple for power steering gearbox. '68 does.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
its all about the +6 inches
Some 68's didn't have the dimple.
If the 3/4 ton frame is a coil spring frame, then it has a few spots of added bracing... a good thing. Otherwise, the only difference you'll find, is you'll need to get cab mounts for a 3/4 ton, they are taller than 1/2 ton. Otherwise, they are the same. |
#4 | |
The Older Generation
Andy, Will the cab mount kit for a 1/2 ton work on a 3/4 ton or are the 3/4 ton frame brackets lower? Reason I ask is because I just bought a 1/2 ton kit to use on a 3/4 ton truck so the cab don't sit so high.... The kit I bought includes the 1/2 ton core support bushings too. LockDoc
#5 | |
![]() Join Date: Apr 2005
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 04-13-2008 at 10:39 PM. |
right, and I think it is just the rear mounts. (I could be wrong) but if you install the wrong ones, the bed won't line up,a nd the fenders will be mounted at an angle.
Thanks guys. My supplier is close so I will just take the 1/2 ton stuff back and trade for the 3/4. LockDoc
