Old 04-13-2008, 08:31 AM   #1
flat68
Suspension Questions
Heres a question for you guys, i have the x member the rear trailing arms bolt to out right now for exhaust mods. I have been thinking and when i lower the rear 5 inches it will bring the axle forward some. wondering if i can or if anyone else has spaced the brackets the trailing arms bolt/pivot on out and bolted them back on to correct the positioning of the rear axle in the wheel well. Was thinking id grind the rivets off and use 1/4 inch aluminum plates to shim the brackets toward the rear. what do you think???
flat68 is offline   Reply With Quote
Old 04-13-2008, 07:07 PM   #2
flat68
Re: Suspension Questions
nobody dealt w/ this?
Old 04-13-2008, 08:10 PM   #3
Riveted1
Tasty Cakes!
Riveted1's Avatar
Maybe someone with more experience can chime in on this, but I don't think the axle will move enough w/a 5 in. drop to worry about moving it back. Only trucks with extreme drops (air suspension) seem to get noticeable movement of the axle. Just my .02
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 04-14-2008, 02:42 AM   #4
matthufham
it won't be off that bad, and a 1/4 inch isn't worth the trouble anyways.
matthufham is offline   Reply With Quote
