Foolish Mortal
Brake Drum question
I know, I know, you're still waiting to hear about the "klunking" issue, but wanted to ask about the "pulsing" brake drum issue mentioned in it (Wife says I have "AAADD" - Advanced Age Attention Deficit Disorder); Anyhow, was thinking of replacing the drum, since it looks like it would cost about the same as having someone turn it (O'reilly's has it for ~$25).
Question is: If the brakes themselves look ok, should I just get the new drum or should I do more? |
Re: Brake Drum question
I would at least make sure the adjuster is working good. Depending on how worn the drum is that you are replaceing you may have to back off on the adjustment to get the new drum on.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
its all about the +6 inches
if you have original drumps, and they can be turned, then turn them. The replacements are junk.
Foolish Mortal
Sisyphus was my mentor!
![]() Join Date: Sep 2002
Turn the old drum! It's old seasoned iron & shouldnt warp like a new one (probally made in china...) probally will. I buy new ones as a last resort.
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
Yes, you can have the old ones turned... make sure they don't turn them too far though, there's not a whole lot of room for going too far on these.
The replacements are pretty lame. No hole to adjust the shoes through, no lip to hook the spring to, and worst of all, they warp like a mo-fo. |
#7 | |
Foolish Mortal
Mebbe I'll buy an el cheapo, pull the old one off, have it turned and then put it back on =] |
the boat guy
i had a drum crack and come apart going down the highway, so i will be the only one here to say buy new ones. price around i know oreileys wasnt the cheapest around here.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
if you get new ones, plan on replacing them at every brake job, that adds $25 a wheel at a minimum.
If you have old ones, have them measured, if they are thick enough, then they are thick enough. |
