Old 04-13-2008, 11:05 AM   #1
BuckLucky
BuckLucky's Avatar
Front springs 72 Blazer for 8 in lift.
Can anyone tell me the differance in the front springs of a 72 blazer vs the front springs of the 73 and newer trucks? From what I can tell ie that the 72 springs are 2 1/2 inches wide at the center pin vs 3 inches wide at the bushings and seem to be an inch shorter. Can I run 73 and newer springs? I am wanting to put a 8 inch lift on and the kit is way cheaper for the 73 and newer than the 72 and older. Any info would be great.
BuckLucky is offline   Reply With Quote
Old 04-13-2008, 02:57 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Front springs 72 Blazer for 8 in lift.
Ya mite want to try down in the 4X4 section or the suspension section, don't know
Btw, Welcome to the boards from Philly, Pa
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-13-2008, 04:43 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
The 73-up front springs are longer. My K5 had a set of 4" 73-up springs on it when I bought it and the rear of the spring was almost touching the frame. I yanked them off and put the proper springs on. To make the 73-up work properly you wold need to move your spring hangers. Seems like probably easier to move the rear hanger back.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-13-2008, 05:09 PM   #4
BuckLucky
BuckLucky's Avatar
Yeah ,thats kinda what I was thinking.Thanks
