Old 04-13-2008, 04:08 PM   #1
Dads 68 GMC
Dads 68 GMC's Avatar
Wtb Ram Horn Heat Riser Spacer
My r.h. ram horn has a flat surface for a heat riser, I want the spacer that goes there that will accept the exhaust donut. I dont think this was a factory item but I saw one on the internet & was hoping somebody will have one,Thanks Philip
Dads 68 GMC is offline   Reply With Quote
Old 04-13-2008, 11:16 PM   #2
nu2-72
Re: Wtb Ram Horn Heat Riser Spacer
If I am thinking the same thing, does this have a butterfly in it?
I have one from a 76 Corvette in the barn. Don't know if that is what you are wanting. I can get a pic tomorrow.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 04-14-2008, 01:02 AM   #3
msgross
msgross's Avatar
I think I have one... Has a butterfly valve in it... let me check too..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-14-2008, 05:51 AM   #4
67cst
i love summertime
67cst's Avatar
i have one here you can have for the cost of shipping, i took some pics but cant post them until i get my laptop going, might be tonight, tomorrow forsure. let me know what you want to do
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 04-14-2008, 05:53 AM   #5
67cst
i love summertime
67cst's Avatar
i should add that it is indeed the factory ramhorn style one with the butterfly style flap...thats the best i could describe it i guess
Old 04-14-2008, 05:31 PM   #6
Dads 68 GMC
Size:  8.9 KBThanks guys but I think you have a heat riser, heres a pic of what I need
Old 04-14-2008, 05:38 PM   #7
Dads 68 GMC
maybe a heat riser would be fine, I have never used one before. Are there any advantages or disadvantages to using one?
Old 04-14-2008, 06:22 PM   #8
jerry moss
Born Psycho
jerry moss's Avatar
just go to your local muffler shop. it's called a "heat riser block" and if they don't have one on the shelf they can order one. we usually keep one in stock where i work. we used a lot of them back in the 80's but not real popular anymore.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 04-14-2008, 06:28 PM   #9
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
You can just grind a bevel edge on the inside of the manifold for the donut to seal into...like on the other side.
PICKMUP is offline   Reply With Quote
Old 04-14-2008, 08:30 PM   #10
nu2-72
Jerry couldprobably answer this better but I believe the item I have with butterfly is used for cold weather start ups. It should hold back on the exhaust and allow the heated air to warm the breather quicker. As the engine warms, the butterfly opens fully and allows the hot gasses to flow from the manifold. This would be through the heat riser pipe to the air breather snout and the shield that goes over the manifold itself.
I may be wrong and will go look right now.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 04-14-2008, 11:00 PM   #11
70inline6
Two seperate entities -
The heat riser butterfly does indeed hold back exhaust gasses on engine warmup. The exhaust is routed through the intake manifold to the other exhaust manifold and out the exhaust. When the spring gets hot on the heat riser the butterfly will open and allow normal exhaust flow.
The air cleaner heat pipe just draws air across the outside of the manifold. The air cleaner flap door will close when the air cleaner sensor cuts off vacuum depending on temp.
To answer the overall question... you can use a standard heat riser and just grind the rivits off the butterfly (leaving the rod) and go with that.
70inline6 is offline   Reply With Quote
Old 04-15-2008, 12:03 AM   #12
neonlarry
neonlarry's Avatar
I got one here:
http://www.lategreatchevy.com/produc...8&dept_id=1267
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 04-15-2008, 03:15 AM   #13
nu2-72
70inline6, you are right. I was thinking about aftermarket manifolds that have no crossover provision. In that case there would be extra heat in the drivers manifold only.
And I was also wrong on my part. Finally found it and it looks like this. Uses a sleeve and donut gasket. It is also flat on one side only.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 04-15-2008, 04:49 AM   #14
Dads 68 GMC
Thanks all, & thanks neon larry,I'll order one from lategreatchevy. if I grind a bevel the donut might not seal & I hate exhaust leaks, Philip
