52" LLC question... help!
OK, I've been searching all over for the answer to this question, but I can't find it... The question concerns swapping to the 52" springs (using rear springs in the front). All the brackets are no problem, but what do you do at the axle? The longer leaf springs are 2-1/2 inches wide, where the springs coming out were 3 inches wide. Do you just mount it up with the plates from the original springs, even though there is a 1/2 inch difference (especially since you can't change the perch on the passenger side, being that it is cast into the housing).
What's the proper way to connect the front end to the 2-1/2 springs?
1988 R2500 Crew Cab Immediate plans- get it running! Future plans- Rear disc swap & Hydroboost Dually conversion with shackle flip-n-switch 4x4 conversion with 52" springs Maybe some new body panels ![]() Who needs a car when they make crew cab trucks? |
Re: 52" LLC question... help!
No one's done the long leaf conversion?
like a rock
![]() Join Date: Nov 2004
maybe this will help? ..... http://www.coloradok5.com/52inchspringswap.shtml
Thanks for the link, it was real informative and a big help.
The only question it didn't answer is the one I am looking for- how do you bolt the axle, with it's perches designed for 3 inch springs, to a 2.5 inch spring? Do you just use the 3 inch hardware? Does the loss of .5 inch (or .25 on each side of the spring) hurt anything?
