Old 04-13-2008, 06:27 PM   #1
Chevyholic
Will it run today?
Chevyholic's Avatar
Guidance Please, Ignition Problems
Howdy Experts, need some help.
I was driving yesterday, approaching an intersection and pulled my foot off the gas. The truck died and wouldn't restart. Got towed to the nearest gas station. Let it sit for about 20 minutes and it turned over and started for about a minute then died and wouldn't restart.
FYI this is a 350 w/HEI.
Based on the fact that it would cool down and start, but not run after heating up, I had the HEI control module tested and it failed, so replaced it. However, it still won't start. Doesn't even sound like it is getting a spark.
Any ideas where to go from here?
Thanks!!
Jaws, the 1971 Chevy Cheyenne Longbed.
She's big, grey, and has an insatiable appetite!
Chevyholic is offline   Reply With Quote
Old 04-13-2008, 06:41 PM   #2
cdowns
cdowns's Avatar
Re: Guidance Please, Ignition Problems
take a sparkplug connected to a plug wire ground it to an exhaust manifold is the way i check for spark// my ears aint so good i cant hear the spark i have to see it
if you have spark i'd change th cas and air filters/
Old 04-13-2008, 07:22 PM   #3
463
463's Avatar
if there is spark take a look at a dirty fuel filter or bad fuel pump. you may have a bad (2nd module in the HEI) or broken wires inside the HEI (too and from the module or coil) ,a coil gone bad on you or a fault in the 12 volt power to the HEI. 463
Trueman
463 is offline   Reply With Quote
Old 04-13-2008, 09:00 PM   #4
Sammy
Check the small wire going to the starter after being stretched and pulled they have a tendancy to touch the manifold or pipe ,short when hot, after cool down they start. Don't ask me how I know.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-13-2008, 09:07 PM   #5
Chevyholic
Will it run today?
Chevyholic's Avatar
Thanks all, I will look at all of this shortly and give it a shot.
Old 04-15-2008, 05:22 PM   #6
Chevyholic
Will it run today?
Chevyholic's Avatar
Ok, so I pulled the distributor cap again to find that the HEI control module wasn't actually plugged in after all. The housing that the module plugs in to was cracked, so it slid in under the connectors rather than between them. However, once I got spark the engine started, but the carb completely flooded out after about a minutes worth of run time. I haven't even begun to start troubleshooting that mess. I do have to say that I'm VERY disappointed in my Holley carburetor. I bought it last year and this will possibly be the second rebuild. The casting job was utter crap and I had to smooth out numerous burrs just to get the float to seat. Of course I didn't find all of this until after the warranty expired.
Flooding that quickly, I'm thinking either the float is stuck, or the power valve. Any other thoughts?
Old 04-15-2008, 07:24 PM   #7
TonyJohnson
TonyJohnson's Avatar
Edelbrock 1406
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 04-15-2008, 07:40 PM   #8
El Jay
Gone to greener pastures
lo
I'd try gently tapping it with a hammer handle to see if that would free up your float(s).
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
