Old 04-14-2008, 03:27 AM   #1
Blue85
Oilfield Trash
Blue85's Avatar
Speedo Gear Calibration
I'm finally getting around to makin my speedo read correctly, I found on this site http://www.transmissioncenter.net/sp...n_______va.htm what gear combos i need, just wondering what "speed" the speedo in these trucks is. It says on the site most speedo's 1965 and up read at 1000 revs per mile, is this true for a 72 truck? BTW, its 700r4 trans, 3.73's, and 28 inch rubber.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 04-14-2008, 06:07 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Speedo Gear Calibration
I'm not close to a speedo to look but this site says some are marked in small numbers at the bottom of the face.
http://www.bgsoflex.com/speedo1.html
LockDoc
Leon
Old 04-14-2008, 03:36 PM   #3
70GMCer
70GMCer's Avatar
You have the same setup as mine except I have 27" tires. And yes, the speedo is 1000 revs per mile.
The gears you need are: Speedo driven gear 40 tooth (black)
drive gear 15 tooth (gray)
The "driven gear is where your speedo cable fits into & the drive gear is in the tail shaft. You have to remove it to replace that gear. Check your colors though, you might already have the gray gear in there, & you'll only have to change the speedo gear.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-14-2008, 06:52 PM   #4
Wrenchbender Ret
The 700-4R trans. is easy to calibrate the speed. Compare the odometer with the mile markers on the freeway. If it gains tenths take out the driven gear & get one with more teeth. If it looses get one with fewer teeth.
Wrenchbender Ret is offline   Reply With Quote
Old 04-14-2008, 08:15 PM   #5
70GMCer
70GMCer's Avatar
It depends if the driven gear fits within the drive gears range. Mine didn't and had to change to get the correct ratio. It's a lot easier to do the calculator method, rather than buying different gears until you get it right. $2 a piece at GM
1997 GMC Sierra Ext
1965 Mustang
Old 04-14-2008, 09:46 PM   #6
Blue85
Oilfield Trash
Blue85's Avatar
ive never changed the speedo gears before, but i do know what has to be done, except, is there any special procedure for makin the gears mesh correctly?
87 Chev 3+3 4x4
Old 04-16-2008, 02:41 PM   #7
70GMCer
70GMCer's Avatar
That's why you have to be within a certain range for the gears to mesh. When they are within that range, they just couple together in side the case. If the two gears are out of that range, they will just bind up and strip, and most likely break into pieces.
1997 GMC Sierra Ext
1965 Mustang
