Old 04-14-2008, 04:10 AM   #1
bedsled71
bedsled71's Avatar
shocks for bagged truck
im not sure what shocks i should run on the rear of my truck. im wondering what everyone else is running and their opinions
bedsled71 is offline   Reply With Quote
Old 04-14-2008, 04:26 AM   #2
lukejames
lukejames's Avatar
Re: shocks for bagged truck
are you bagged? lay frame? static? or stock?
lukejames is offline   Reply With Quote
Old 04-14-2008, 04:39 AM   #3
bedsled71
bedsled71's Avatar
layin frame
Old 04-14-2008, 05:41 AM   #4
lukejames
lukejames's Avatar
what you need to do is find a good spot for your shock mounts. measure the distance laying out and distance airred up all the way. take those numbers to your local parts store and tell them you want a pair of shocks that collapse to your lowest number and extend to your highes number. they will be able to find you something close to your spec.
good luck.
Old 04-14-2008, 06:24 AM   #5
bedsled71
bedsled71's Avatar
what i was looking for was the brand of shocks others were using and how they liked them
Old 04-14-2008, 06:26 AM   #6
lukejames
lukejames's Avatar
ok kyb makes a good shock
Old 04-14-2008, 06:32 AM   #7
Slmd92DIME
Slmd92DIME's Avatar
I have stock rear and front shocks. The 65 stock rear shocks get a good bit of travel so I used them.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 04-14-2008, 06:33 AM   #8
GRIMSS
GRIMSS's Avatar
mini truck mag has a tech this month on shock placement for what shocks you want to run.
it goes like this.
desired wheel travel / Shock stroke = X ( shock postion, measured from the frame pivot )
X is a % of the total lengh of the a-arm or the rear lower bar
here is the example they gave.
Rear
10" (travel) / 6.5" (stroke) = 0.65
the rear bar they mounted it on was 30.75. 0.65 * 30.75 = 19.9
so they mounted it 20" from the frame pivot. then collapsed the shock and made the upper fame mount.
the did the same on the front.
Don't know if it will help but I was wondering it myself.
by the time i got all this typed i see you just wanted a brand, maybe it will help someone else sorry.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 04-15-2008, 11:40 PM   #9
Frizzle Fry
Frizzle Fry's Avatar
I just installed Monroe Sensa-Track all the way around and like them. They were recommended here on the board by a few people.
Frizzle Fry is offline   Reply With Quote
Old 04-16-2008, 12:56 AM   #10
bedsled71
bedsled71's Avatar
those are one of the shocks ive been looking into.. im not sure what shock to get though because my bags are mounted pretty forward on my links so i can get alot of lift but ill maybe need a stiff shock so i can cruise as a low ride height. so im leaning towards some rancho 9000's so i can fine tune it
Old 04-16-2008, 01:36 AM   #11
XXL
Seņor Member
XXL's Avatar
This is a common topic in the forum.
XXL is offline   Reply With Quote
