Cab support replacement
could somebody tell me the steps it takes to get the old rotted cab supports out and to put new ones in please...it looks easy enough but i know it will be harder then i think.. please help i know its not good to have 3 rotted cab supports
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
Re: Cab support replacement
first remove the bolts
jack up the section you are working on then remove the mounts put the new ones back in with new hardware is possible you may need to replace the core support bushings as well good luck |
where do i put the jack
the three i need to replace basically nothing is left of them..a couple are filled with foam
are you taling about the bushings or the sheet metal?
![]() Join Date: Jan 2006
I had to remove my gas tank in order to get at the rear cab mounts. I used a jack and some lumber under the outrigers to jack the cab up in order to remove the bushings
the metal is all rotton and missing on the back two supports so i need to replace them and my pssenger side is shot to...they are filled in with that expanding foam and i dont really like that.. i need to tell my dad the procedure on how to do this so he will let me start doing it..hes kinda anal on some stuff and hes worried that my ability on this stuff but i dont think its that hard...ill prolly have to move the tank out to... but i dont need to weld the new ones in do i???
![]() Join Date: Jan 2008
the cab supports are welded in place with spot welds from the factory. they will need to be drilled out so you can remove them. also you will have to weld the new supports back in.
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 ![]() http://i195.photobucket.com/albums/z...en58/001-2.jpg |
I need to do the same thing. Take pics when you do it if you don't mind
i am not 100% sure i am going to do this..i have to round up a welder first but if i do end up doing the replacement i will put pics up
