Old 04-14-2008, 10:19 AM   #1
tsetsaf
Blazer Tank Conversion - Sending Unit Wire
What have you used to wire the new tank behind the rear end. I spliced my original wire but there is too much resistance so it reads "E".
Thx
71 C-20 Custom Camper
California Truck
tsetsaf is offline   Reply With Quote
Old 04-14-2008, 10:38 AM   #2
JimKshortstep4x4
Re: Blazer Tank Conversion - Sending Unit Wire
With the gauge setup more resistance should make the dash unit read beyond full since "0" ohms = empty and 90 ohms = full.
If you are reading empty then I would suspect that the wire from the tank is grounded to the truck somewhere. Try disconnecting the sender wire at the fuse panel to see if the dash guage reads full with the wire disconnected.
Jim
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-15-2008, 04:04 AM   #3
tsetsaf
That is an easy answer... the gauge does not read full when the wire is disconnected; rather it reads 1/4 tank. Once I hooked up the wire it went to "E".
Gauge Problem?
California Truck
Old 04-18-2008, 03:48 AM   #4
tsetsaf
ttt
California Truck
Old 04-18-2008, 04:03 AM   #5
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Guage is 30 ohms, Sending unit is 90 ohms. Put a 45 or 47 ohm resister *depending on what the parts storr has in stock* inline right before the guage.
Run a search for fuel guage ohm and you should get what you need.
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
