Old 04-14-2008, 11:17 PM   #1
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Watt's and leaf
Anybody here ever see a leaf spring setup with a watt's link? For the time being, until I can afford a KP cantilever setup, I'm going to be running an air over leaf setup on my 72 GMC and was thinking about throwing in a watt's in for fun. Am I crazy?
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 04-14-2008, 11:20 PM   #2
bedsled71
bedsled71's Avatar
Re: Watt's and leaf
a watts woulndt do anything with a leaf but be a waste.. its not needed since the leafs are what holds the rear end in place..
bedsled71 is offline   Reply With Quote
Old 04-14-2008, 11:20 PM   #3
bedsled71
bedsled71's Avatar
Re: Watt's and leaf
so to answer.. yeah maybe you are crazy
Old 04-14-2008, 11:22 PM   #4
bedsled71
bedsled71's Avatar
Re: Watt's and leaf
or maybe your talking about cutting the leaf springs right behind the axle and using the front part as trailing arms???
Old 04-14-2008, 11:33 PM   #5
dieselarmy13
Re: Watt's and leaf
I was thinking mostly in the looks department, cause you have to admit, they look pretty trick. That, and I don't plan on staying with leafs forever, just doing the whole one peice at a time thing, you know? I've also heard that you can get quite a bit of side to side movement with a leaf setup.
Old 04-15-2008, 01:37 AM   #6
bedsled71
bedsled71's Avatar
Re: Watt's and leaf
with leafs your axle wont get any side movement, if your talking about laterial movement.. but it will get side to side movement if you are talking about "side to side" with bags which means one wheel up, one wheel down
Old 04-15-2008, 02:54 AM   #7
Shane
Shane's Avatar
Re: Watt's and leaf
you're want to add a Watt's link simply for looks?
Shane is offline   Reply With Quote
Old 04-15-2008, 03:16 AM   #8
dieselarmy13
Re: Watt's and leaf
Fer now! I'm eventually going with a four or six link, and I know, I should buy that first, but I'm just trowning ideas around. Something to make all the minitruckers scratch their heads, maybe even wear there hats right.
Old 04-15-2008, 03:40 AM   #9
hotrodhomi
hotrodhomi's Avatar
Re: Watt's and leaf
I'm not sure it will get the reaction your are looking for.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 04-15-2008, 03:48 AM   #10
bedsled71
bedsled71's Avatar
Re: Watt's and leaf
you will have people thinking you dont have ANY clue what your doing..
and your watts link would have to be set up at the right height and travel that your link setup would be..
Old 04-15-2008, 04:09 AM   #11
dieselarmy13
Re: Watt's and leaf
I guess I'll just let this one go. Probably save me a lot of money, anyway.
Old 04-15-2008, 04:32 AM   #12
bedsled71
bedsled71's Avatar
Re: Watt's and leaf
it would be great but not while you have the leafs in it
Old 04-15-2008, 04:34 AM   #13
hotrodhomi
hotrodhomi's Avatar
Re: Watt's and leaf
agreed.
'66 impala ht
Old 04-15-2008, 04:57 AM   #14
dieselarmy13
Re: Watt's and leaf
Thats why I love this site, it often saves me from my bright ideas.
Old 04-15-2008, 07:28 AM   #15
PBFAB.COM
PBFAB.COM's Avatar
Re: Watt's and leaf
If you have removed some leaves, it may not be a bad idea to use something to help eliminate lateral shift. The leaves will keep the rear-end in place, but you'd be surprised how much lateral shift you can get... especially after removing multiple leaves.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 04-15-2008, 08:37 AM   #16
dieselarmy13
Re: Watt's and leaf
Thank you! The master has spoken! I know I've lost quite a few brain cells over the years, but I know I have heard and/or read about this somewhere. I'm sitting on two leaves right now, and it is definetly sloppy.
Old 04-15-2008, 05:39 PM   #17
bedsled71
bedsled71's Avatar
Re: Watt's and leaf
well then can you explain where this movement is coming from.. the leaves are still bolted front and back with the axle bolted to the middle.. i guess i can understand that the leaves will bend and twist but how much could it really move to one side or the other? inches?
Old 04-16-2008, 05:40 AM   #18
PBFAB.COM
PBFAB.COM's Avatar
Re: Watt's and leaf
If multiple leves are removed from the pack the rigidity and strength will be compromised. The spring will allow lateral movement, just like it will wrap. The lateral movement won't be as severe as the wrap, but could be an inch or more. Most people wouldn't worry about it.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
