Old 04-15-2008, 01:51 AM   #1
Kixwy2
Kixwy2's Avatar
Fuel Economy and $4 gas...
First, my specs:
1974 GMC 1/2 ton 2wd CA truck
GM crate 350/260ft lbs torque - stock with 1000 miles on it
rebuilt Rochester quadrajet carb
original manifold with EGR blocked off
new fuel pump, fuel lines, hoses, etc
new distributor and accessories
Timed to 11* BTDC
12 bolt rear
31" BFG All Terrains
and a ghetto dual exhaust system of unknown origin on the list to be replaced...
Ok, so I want to make sure I am getting the best gas mileage I can with this truck. I've tuned the carb so the fuel mixture is good and leaned it out some, but not enough to cause a stumble once it's warmed up. I'm not a pedal to the metal kind of driver, but it seems I'm not getting the mileage I should be. Feels like it's around 8-10 MPG, which sucks. It sounds good, and runs great, but can I get better MPG performance?
Sort of a novice at the timing/tuning thing and I'm willing to take it to a shop if it will help significantly, but also willing to try it myself.
I'm just tired of going 120 miles on a tank of gas. And paying $60 to do it.
Thoughts?
1974 GMC C-10; my new addiction
1998 4 Runner; daily driver
Kixwy2 is offline   Reply With Quote
