Old 04-15-2008, 02:56 AM   #1
thump16
thump16's Avatar
HEI question
where does the fusible link go that is attached to the HEI power (pink)connector on the engine wiring harness. The reason I ask is that I picked up a silverado engine wiring harness from the salvage yard and my truck is a scottsdale that had MSD set up installed so my HEI power wire didn't have a connector on it.
thump16 is offline   Reply With Quote
Old 04-17-2008, 06:29 AM   #2
lurch115
lurch115's Avatar
Re: HEI question
it should be down by the starter solenoid about 2 inches or so away...
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
