Old 05-05-2002, 04:41 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Thumbs up Pontiac into truck motor mount pics
Some one did some good work under the hood of this pig. For those unaware, this would be the Pontiac 350 in my '70 one ton Longhorn. The comparison pics are the proper chevy 350 in my '69 1/2 ton GMC.
The motor mount towers seem to hold the motor lower in the frame, which since the Pontiac has a higher deck height, this is a good thing. The towers are also longer...from front to back.
The Chevy engine is mounted in the 2 forwasd holes, while the Pontiac is taking the forward AND the rear hole.
Some one did there homework here.
Is there a chance that these towers are 4X4 towers? How about big block towers?
Here's the pics;
These are all driver side pics.
Here is the Longhorn...
same angle in the GMC....
See how low this tower seems to hold it...lower and further out.
compaired to the chevy mounted engine.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 05-05-2002, 04:55 PM   #2
Johns70
Johns70's Avatar
Post
those are both big block towers the pontiac is sitting on 72 bb towers and yor gmc is sitting on 67-71 towers thats why the motor mounts rub the frame tower a little.hope this helps.
project 70 chev swb rebuilt 396bb{402}rebuilt th-400 3.73 limited slip 4/5 drop
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 05-05-2002, 04:56 PM   #3
imaindianoutlaw
GMC SHORT FLEET F/S
imaindianoutlaw's Avatar
Post
Where in the hell did they get those mounts and I can not understand how the mount bolts up to it?
Charles W. Hein
S. Williamsport PA
imaindianoutlaw@yahoo.com
REFRIGERATION TECH
1971 Rolling chassis
FOR SALE
1963 Pontiac Tempest
1965 Pontiac GTO
1956 Pontiac 2 dr
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
imaindianoutlaw is offline   Reply With Quote
Old 05-05-2002, 05:01 PM   #4
Longhorn Man
Post
Johns70, you sure bout the GMC towers? I had the exact same ones in my old Longhorn, and it was an unmollested rig.
Indian....give more detail on what you're looking at, and I'll zoom in on it a little better.
Old 05-05-2002, 05:09 PM   #5
Johns70
Johns70's Avatar
Post
the engine mount bolts to the front two holes and the bottom one angles back and bolts to the back hole.if this is the case it's a big block mount 67-71.i just rebuilt my bb motor and i switched from the late to the newer mounts like your pontiac motor has.
Old 05-05-2002, 05:24 PM   #6
Johns70
Johns70's Avatar
Post
i looked a little closer and on the gmc it has the rubber under the mount also, if it has a large hole in the tower it is definatley a bb mount.
Old 05-05-2002, 05:27 PM   #7
Longhorn Man
Post
Interesting...can anyone show me a small block tower then?
Old 05-05-2002, 05:37 PM   #8
Johns70
Johns70's Avatar
Post
they make two different towers for the small block one set for the front mounting holes and another set for the back mounting holes.they look simalar to the bb towers, instead of angleing back they go staight down to lower hole that sits in line with the top two holes,and if i remember right the bolt hole that ataches the rubber mount to the tower is small dia.and off subject the 292 six uses one tower in front and one tower in back mount, and the 250 six uses the same on both sides i think, its been so long since i did any six cycle and small bock stuff. hope this helps
Old 05-06-2002, 10:48 AM   #9
Longhorn Man
Post
ttt, anyone have pics of the proper small block towers?
Old 05-06-2002, 11:01 AM   #10
Desert Rat
Desert Rat's Avatar
Post
I see a set of 68-71 BB towers,and a set of 73 up style-they look similar to the 72's
Desert Rat is offline   Reply With Quote
Old 05-06-2002, 02:24 PM   #11
Fast68Chevy
Fast68Chevy's Avatar
Post
72bb towers have rounded top flange corners- not square ones like in 73-up for all engines,
73-up BB ones are roughly 1/2" shorter than SB ones in length, will have to measure my 76 BB ones ot make sure of that and compare ot all my 73-80 SB ones.
72 BB oens are one of a kind, go compare 72 bb ones to 73-up ones and you wil see what i mean
what towers are those in the GMC ? 68-71 BB ?? or V-6 ones ?
[This message has been edited by Fast68Chevy (edited May 06, 2002).]
Fast68Chevy is offline   Reply With Quote
Old 05-06-2002, 07:24 PM   #12
Longhorn Man
Post
In the GMC, I had thought they were small block. The old Longhorn had the same ones too...now that i think about it, the GMC's left tower if from the Longhorn, and the right one was in there when i bought it.
Old 05-06-2002, 07:52 PM   #13
>X<
registered IWATA user
>X<'s Avatar
Post
they sure look a helluva lot better than the mounts on my pontiac 350 in my 71, mine are homeade and look like crap, but they do the job i guess, my motor sits a little higher i think though
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black
-'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end.
-01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny.
Take off that Von Dutch hat before i stab you with a 000 Mack.
>X< is offline   Reply With Quote
Old 05-06-2002, 07:56 PM   #14
Longhorn Man
Post
I wouldn't wanna go much higher than this one...
Old 05-06-2002, 09:04 PM   #15
imaindianoutlaw
GMC SHORT FLEET F/S
Post
Find a truck where the pontiac motor still uses a fan shroud!
Charles W. Hein
S. Williamsport PA
REFRIGERATION TECH
FOR SALE
1965 Pontiac GTO
1956 Pontiac 2 dr
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
Old 05-06-2002, 09:06 PM   #16
Longhorn Man
Post
It's all coming out anyways...
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-07-2002, 08:00 AM   #17
imaindianoutlaw
GMC SHORT FLEET F/S
Post
Not for me! Its all goin in some day? Talked to the wife last night, and was talking about just getting a loan to buy a truck? If I build one I will have like 20,000 into the truck easy! I am very picky with my vehicles, I do it right or dont do it. Its never cheap! But I still have this 428 to use, os if I buy a nice truck I will still use this motor at some point!
Charles W. Hein
S. Williamsport PA
REFRIGERATION TECH
FOR SALE
1965 Pontiac GTO
1956 Pontiac 2 dr
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
