Old 04-15-2008, 05:15 AM   #1
pissonNOS
senior member
pissonNOS's Avatar
brake help please
once i got my install done of the ECE disc brake swap i notice now i have a really hard pedal and it takes a little bit to stop. I noticed today a couple times when i stopped at gravely intersections my rear seem to lock up, any one know what i did wrong or should be adjusting?
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 04-15-2008, 09:30 PM   #2
pissonNOS
senior member
pissonNOS's Avatar
Re: brake help please
Ttt
69 GMC bagged
Old 04-15-2008, 10:01 PM   #3
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Did you install a porportioning valve? If you did not,that will cause your rear brakes to lock up. If you did install one and it is not adjusted right, that will cause the rears to lock up too.
I do not think that the prop. valve would cause your brake pedal to be hard though. did you bench bleed your master?
Did you install a booster too? If so where did you get your vacume from?
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
