Need sum opinions on these
Don't know which to get and would look the best need sum help.17x8 Hopsters with -11 offset or these mbmotoring in 17x8 with -6 offset.
'72 chevy shortbox---454cid/th400 ![]() ![]() |
Re: Need sum opinions on these
I like the rims in the 1st picture myself.
Joe |
Between Trucks...
Beat it to fit, Paint it to match... ![]() |
![]() ![]() Join Date: Jul 2002
I think you will have a hard time running a 6 inch offset on our trucks. Most I see are 4.5 to 5.5 that will clear without issues.
i don't know anything about the backspace, but i think the first picture looks much better
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
I like the first wheel..... I even did a little photo-chop for ya'
R.I.P. Scott Kalitta
C10 addict
I think you are confusing backspacing with offset. A 10" wide wheel with a -6 offset means the mating surface of the wheel is -6mm off of center, which would give you a 4.76 backspacing (6mm = .24") A 10" wide wheel with 0mm offset has a backspacing of 5"
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS Last edited by mahanian; 04-16-2008 at 01:21 AM. |
So do ya think they will fit with a 17x8 rim and -6 offset.With 255/50/17 on front and 275/50/17 on the back.Scared to order them incase they they don't fit.Anyone got pictures of similiar setup to get an idea of how they'll look.
C10 addict
The rims should fit fine, but 275/50 is pretty wide for an 8" width wheel. That tire is almost 11" wide, you will have a lot of rubber hanging out on the sides. Do they not make a 17x9.5 you could put on the rear?
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
How bout a 275/55/17 on the back.
C10 addict
That's the same width tire, just taller. The first number is the width in millimeters so to convert to inches divide by 25.4. The second number is the sidewall height as a percentage of the width. So, a 275/55 is:
275/25.4 = 10.83 inches wide and 10.83 x 55% = 5.95 inch sidewall the 275/50 = 5.42 inch sidewall If you already knew that, then ignore this post ![]()
K thanks Mahanian,I didn't really no that.You got anyother tire combos that would look good without goin to a 9.5 wide wheel.
#13 |
C10 addict
Since you aren't staggering the wheels, meaning different widths front to back or different diameters front to back, I'd run the same size tire all the way around. 255/50 or 255/55 on 17" wheels would look good with a 4/6 drop. There are a couple threads of members posting pics of their wheel/drop combos, those might be helpful
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS Last edited by mahanian; 04-16-2008 at 04:08 AM. |
#14 |
It has been my experience that the only way to tell how wide and tall a tire is is by measuring it with a tape. Every manufacturer's tires are different. I always like to see them in person and measure them before buying tires.
#15 | |
I posted this above..... ![]()
#16 |
i have hopsters on my s series and i love how they look
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 ![]() ![]() |
