Old 04-15-2008, 07:20 PM   #1
whatnow123
whatnow123's Avatar
AC hose Kit
Hi Everyone,
Like everyone else, it's time to start hooking up the AC in the ride.
Anyway, I have a vintage AIR evap unit and I have pieced together the under hood components however, I need all the connectors and "cut to fit" hoses.
Anyone know where to get the connectors for the compressor, condenser and drier lines?
Thanks in advance!
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 04-15-2008, 07:51 PM   #2
jdhcth
jdhcth's Avatar
Re: AC hose Kit
I bought my entire system from Nostalgic Air Parts. They have all the individual pieces too.
http://www.nostalgicairparts.com/?cat=13
Good luck,
JD
jdhcth is offline   Reply With Quote
Old 04-15-2008, 07:55 PM   #3
Zonaman
Zonaman's Avatar
Re: AC hose Kit
Locally try AAPAK or Arizona Mobile Air. Either of these folks can supply parts and work up custom hoses for you.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 04-15-2008, 09:58 PM   #4
john
member #16
john's Avatar
Re: AC hose Kit
I bought all my fittings and hose from napa. I put the fittings on and cut the hose to length and marked the orientation of the hose to fittings and took them back and had them crimped.
john is offline   Reply With Quote
Old 04-15-2008, 11:42 PM   #5
Psycho71
Psycho71's Avatar
Re: AC hose Kit
Napa here too. Goodyear rubber, all the fittings you could need, and my local store crimped mine free once I got them assembled. I did the same, installed the fittings, cut the hoses, and taped them w/masking tape. They just crimped them with the masking tape on so they wouldn't loose the index.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
