Old 04-15-2008, 07:41 PM   #1
6RoyBoy1
Need Some Advice....
I Have A 1973 Chevrolet Truck & My Gas Tank (Hose) Is Leaking. So I Need To Replace The Gas Hose And Noticed That The Hose Is On Top Of It? (The Gas Tank.) Do I Have To Drop The Tank To Get To The Hose And If So, How Do I Go About It W/Out Messing Everything Up? Thanks In Advance 4 Your Help.
6RoyBoy1 is offline   Reply With Quote
Old 04-15-2008, 07:46 PM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: Need Some Advice....
pull the bed, it's easier imo
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 04-16-2008, 07:41 AM   #3
tyjoja
the beds not too hard to take off. 8 bolts unplug the light harness under and above the license plate and unscrew 3 screws at the tank filler flange. a guy on each corner and lift it up and walk it off. good luck bob
tyjoja is offline   Reply With Quote
Old 04-16-2008, 03:13 PM   #4
wicked_sky_gazer
Living Legend
wicked_sky_gazer's Avatar
Thats the way i wish i had been able to do mine, but since i didnt have an extra 3 bodys at my disposal i pulled 7 of the 8 bracket bolts, (leaving the rear top bolt in place but slightly loose) and pivoted the tank down in the front. Since i have small forearms i was able to reach up under it and and make my repairs fairly simply. but its time consuming doing it this way and there is a good chance of coming out with some scratches... o and dont forget to undo the filler hose still. GL!
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia..
project is temporarily on pause again... Thankyou wonderfull economy.. check it out
Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap
East Ok meet East Ok date
Tony
wicked_sky_gazer is offline   Reply With Quote
Old 04-17-2008, 09:27 PM   #5
6RoyBoy1
Thanks for the advice, sounds like pulling the bed might be the easiest. I Appreciate everyones comments and suggestions
Old 04-21-2008, 02:08 AM   #6
olivedrab
no pulling the bed is not easier unless you have an easy way of pulling the bed off and moving it around...ive had to drop my tank a few times due to damage from wheelin and its really not that bad. just try and burn all the gas in it first so its not so heavy
87 chevy-350 tbi-4x4-swb-4" lift-37inch claws
72 gmc- 350 carb- 2wd-lwb, soon to be 4x4?
olivedrab is offline   Reply With Quote
Old 04-21-2008, 03:19 AM   #7
Kixwy2
Kixwy2's Avatar
Put a jack under the tank with a 3/4 inch piece of plywood for the tank to rest on... jack it up, then loosen the bracket bolts. Then you can lower the tank without dropping it on you or have it torque the bracket all to hell.
If you're a one person operation this works amazingly well. ...Which reminds me - I have to do this again soon to fix the fuel gauge.
1974 GMC C-10; my new addiction
1998 4 Runner; daily driver
Kixwy2 is offline   Reply With Quote
