04-15-2008, 07:54 PM | #1 |
I miss this truck.
Power brake issue - No pedal return.
I know power brakes have been done to death, but I can't find my specific problem in a search.
So, I upgraded to power brakes. I left the front drums alone, I may upgrade to disks later, but it would cost more right now than the truck is worth. I just needed to get a new M/C, so i put a booster on budget consciously while I was at it. To make a long story short, my pedal won't come back up. I get real good pressure, the truck stops better than it ever has, but when I let off the pedal it comes up 1/2 an inch (just enough to release the brakes) then stops. I have to pull it up with my tow to get the shoes completely off the drums, and to turn off the brake lights. Any suggestions? I've bled them, I've adjusted the pushrod from the pedal to the booster, I've and repeated the process.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. Last edited by Tynee; 04-15-2008 at 07:54 PM. |
04-22-2008, 07:04 PM | #2 |
I miss this truck.
Re: Power brake issue - No pedal return.
Noone has had this issue? I guess I'll go post in the 67-72 pickup forum.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
04-23-2008, 02:38 AM | #3 |
member #16
Is your return spring present?
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
04-23-2008, 03:33 AM | #4 |
It's Better With Nitro
X2...sounds like the return spring may have come un-hooked.
04-23-2008, 05:12 AM | #5 |
I miss this truck.
Yeah, I wondered about that, too. Unfortunately, its not that easy. The spring is in place. I wonder if replacing it would cure my ills?
04-23-2008, 05:32 AM | #6 |
Well, Whoop-dee-do!
I've seen it before- most likely an internal booster problem. Either it isn't completly exhausting the vaccum, or something is dragging inside- or a an internal check valve sticking....
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
