Old 04-15-2008, 08:18 PM   #1
davidh
davidh's Avatar
West coast Mirror mount question
When I got my truck the mirrors were taken off. I have since sanblasted and painted them. Can someone tell me if the bottom screws originally are self tapping or do I need to get a screw and place the bolt from inside the door? Also show some pics of the top of the door screw and bolts please.. david
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing.
davidh is offline   Reply With Quote
Old 04-15-2008, 08:29 PM   #2
1969K10
1969K10's Avatar
Re: West coast Mirror mount question
Mine have little studs that spot weld from inside the door, and then just the threaded parts sticks out, and you hold the mirrors on with acorn nuts.
However, the bolt & nut thing would work well, I'd think.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 04-15-2008, 11:37 PM   #3
Willys47
Willys47's Avatar
the Assembly book calls them a screw and it does not show any nut on the inside of the door skin the top mount is a bolt with a nut
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 04-16-2008, 12:39 AM   #4
Zonaman
Zonaman's Avatar
Got my set off the internet. Came with nylon inserts that fit in holes you drill through the doors, they're kept in place with hex screws. Here's where mine wound up:
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 04-16-2008, 03:59 AM   #5
davidh
davidh's Avatar
Where did you find those screws zonaman
