Old 04-16-2008, 12:57 AM   #1
travistidw
No spark from distributor. Need Help!
I just got done installing a 350 with a blower, and a TH-400 into my 69 step side. The engine before just quit while going 60 mph, with no sputtering or signs of stalling. I was able to get it to crank but it would never fire up. The new engine ran before the install, and i have 12v going to the coil from the starter, and to the distributor from the coil, but no spark. I also tried to bypass and run a direct wire from the battery to the distributor, and still nothing. I heard that the inline fuses could be fried, but tested them and they had power. I'm at a dead end with no ideas on how to fix it and want to avoid the mechanics. Can anyone help?
travistidw is offline   Reply With Quote
Old 04-16-2008, 01:32 AM   #2
cdowns
cdowns's Avatar
Re: No spark from distributor. Need Help!
is this a points or hei dizzy? if its points have you cleaned the points and set the dweel?
Old 04-16-2008, 01:47 AM   #3
Steelawork'n
Just hang'n around
Steelawork'n's Avatar
It is possible to fry coils, so keep that in the equation.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year.
Steelawork'n is offline   Reply With Quote
Old 04-16-2008, 02:00 AM   #4
travistidw
It is a point distributor, and I never took the dist. Of the engine so I didn't think the points needed to be reset.
Old 04-16-2008, 02:13 AM   #5
Steelawork'n
Just hang'n around
Take this opportunity and get an HEI system. You'll be glad you did. These things are virtually maintenance and hassle free.
Old 04-16-2008, 02:49 AM   #6
89 crew
Take the distributer cap off and have someone hit the key. make sure the shaft is turning and you didn't shear a key.
89 crew is offline   Reply With Quote
