04-16-2008, 04:26 AM | #1 |
Stepside Fanatic!
HELP needed with identifying year of ignition lock required!
Hi, I am planning to swap out my non-tilt steering column with a tilt one I bought off ebay a while back. The seller wasn't sure what year it was from, and it came with no ignition lock cylinder or key. I know they are available for sale, but wondering how to get the correct one for my "new" tilt column?
Any help GREATLY appreciated! Many thanks! |
04-16-2008, 04:39 AM | #2 |
Robert Olson Transport
Re: HELP needed with identifying year of ignition lock required!
well maybe if you post some pics of the column we can help you out
04-16-2008, 07:02 AM | #3 |
Stepside Fanatic!
OK,here's some pics of my unknown year tilt column...
04-17-2008, 05:03 AM | #4 |
looks like a 73-82 column to me any cylinder should work from those years
if you take the turn signal switch out you should see if there are clips or a screw in there to hold the cylinder in
04-17-2008, 08:08 AM | #5 |
Stepside Fanatic!
I dunno, I looked in some of the catalogs I have, like LMC and others, and they show different ones for tilt or no tilt wheel, and different ones again for 73 to 78 and later, so I really don't know what the differences are....
04-19-2008, 01:21 AM | #6 |
does it have a dimmer switch located down by the ingnition switch?? if not then i am positive that is a 73 through 78 column...as they had the dimmer switch on the floor. that and that looks like the older style ignition switch to me... ya might try backing away from the column a bit and getting more of it in one pic...would be alot easier to tell
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L |
04-19-2008, 01:27 AM | #7 |
1962 C-10
My old 83 had the dimmer switch on the floor. I think 84 was the first year to have the dimmer switch on the column.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
04-19-2008, 01:28 AM | #8 |
Real Projects never die
73-83 had dimmer on the floor if im right, then 84 went to column.
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
04-20-2008, 11:07 PM | #9 |
Stepside Fanatic!
Hm, I'll take a couple pics from farther away, maybe borrow my wife's camera for clearer shots. I'll check on if it has a dimmer switch on the column (?) Not sure how to tell if it does though...
04-22-2008, 07:49 AM | #10 |
Stepside Fanatic!
OK, I pulled the trun signal cam out tonight and took a look behind it. I do NOT see any screws to hold the ignition key switch in there, or even a screw hole anywhere for that. At the bottom of the key switch "wel"l, there is a sort of horizontal slot (at 90 degrees to the well) in the area behind the turn signal cam, and kind of a slot in the other side of the well also. And running down the well is a groove, which near the bottom turns into a square hole for some kind of clip? I am guessing? Any ideas so far?
04-22-2008, 07:51 AM | #11 |
Stepside Fanatic!
Hey - I forgot to ask: if the dimmer switch is on the column, where is it located on there?
