Old 11-01-2002, 02:06 PM   #1
Tom
driving is in my blood
Tom's Avatar
keyed 12v power source?
I have several things that require a keyed on 12v power source. So right now that means I have 3 wires going to the intrument fuse in the fuse block. I dont think this is a good idea, but I dont know electrical very well. Is it ok having all these wires going to one spot or is there another place on the fuse block I can attach a wires too thats keyed 12v? Thanks
Old 11-01-2002, 02:14 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Tom,
if you have three things tied to the instrument panel fuse, yes you are overloading this circuit. But if it's not blowing any fuses, it should be ok.
Why not move these wires to one of the ign spaces on the fuse block and then use an inline fuse holder in the wire.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 11-01-2002, 02:22 PM   #3
Tom
Tom's Avatar
sounds like a plan. Now I have to find a ignition spot, since most of the lettering is worn off
Old 11-01-2002, 03:06 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
If I remember correctly, there are two ignition sources at the bottom left side of the fuse box. They are single type connection. All you need is a spade male connection. I use one for my amp.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 11-01-2002, 03:41 PM   #5
BigRed
So, these are just un-fused external connections? That's interesting. I'll have to see if mine has them.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 11-01-2002, 04:16 PM   #6
gchemist
gchemist's Avatar
Yes they are unfused. I also need to correct my statement. The power source is for my digital tach not my speaker amp.
