Old 04-16-2008, 06:02 AM   #1
ssfirefighter
Brake trouble
I have replaced my master cylinder x 3 now. I just bought a new, and not rebuilt unit. I drove it for two days with a little bit of spongy feeling, and was waiting to bleed them. On the way to work this morning I felt a shudder and started to pull over to see what it was, and noticed that I had no brakes. They felt really spongy, then the pedal went to the floor and would not return itself. I flipped it up with my foot, and pressed again. I got a little pressure, then back to the floor and no return again. Any suggestions?
ssfirefighter is offline   Reply With Quote
Old 04-16-2008, 06:10 AM   #2
Camper Power
Camper Power's Avatar
Re: Brake trouble
did u bench bleed the master cylinder? no offence, i knew somone that forgot to and he had some troubles that u mentioned
eh
1970 Chevy C20 daily driver
1975 GMC Jimmy 4x4 project
1966 GMC C10 Dad's project
Camper Power is offline   Reply With Quote
Old 04-16-2008, 06:12 AM   #3
ssfirefighter
Re: Brake trouble
Yes I did. I actually mounted it and bled it from the pedal back into itself, then re-attached the lines / proportioning valve.
Old 04-16-2008, 06:35 AM   #4
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
Re: Brake trouble
Have you checked the wheel cylinders for leaks or failure ? That's what mine did when I lost a wheel cylinder . Just my thoughts . Bob
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 04-16-2008, 06:37 AM   #5
ssfirefighter
Re: Brake trouble
I haven't actually looked at it yet. I had it towed to the house, and had to continue on to work. I am just looking for opinions for when I get home tomorrow.
Old 04-16-2008, 03:22 PM   #6
Shyguy
Junior Member
Shyguy's Avatar
Re: Brake trouble
Check the fluid level and then check all the wheel cylinders and flexible hoses.
Good Luck
Danny
Shyguy is offline   Reply With Quote
Old 04-17-2008, 04:47 AM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Brake trouble
This maybe your problem. You need the master perfectly level and then bleed it. I would bench bleed it with the prop valve on it.
dwcsr is offline   Reply With Quote
