04-16-2008, 07:20 AM | #1 |
seat belt switch
i got these seat belts off ebay to install in my '72 c10. any recommendations to install these without risking integrity? the buckle sides seem too short to attach to the existing bolts for the factory belts. is there hardware for them that i'm unaware of?
04-16-2008, 01:56 PM | #2 |
67-72 Addict!
Re: seat belt switch
Why did you buy a mixed matched set (2 point and 3 point)??? Normally the "reciever" which mounts behind the seat is NOT retractable. I have no clue how safe it is to run retractors on both ends of the belt. The way I do it is use an angle bracket from Home Depot and run it between the plastic on the back side of the retractor and bolt it together and bolt it to the floor with a big washer under the floor but a plate would be safer. Here are some pics:
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 04-16-2008 at 02:01 PM. |
04-16-2008, 07:44 PM | #3 |
it's not mixed. they are both 2 point seat belts. truckandcarshop.com sells these exact belts. i guess i can sell them if they won't work.
1972 Chevy C10 Long Bed 454 Big Block Turbo 400 3 Speed Dual Flowmaster Edelbrock 750 Carb Power Steering Disc front brakes Drum rear brakes B&M Floor Shifter |
04-17-2008, 08:16 AM | #4 |
i stand corrected. they are mixed. i see where the difference is. can i use heavy duty L brackets? should i not use them and get the correct ones instead?
