Old 04-16-2008, 03:27 PM   #1
OhNoJoe
OhNoJoe's Avatar
What to take from a 2007 Silverado 1500 5.3
I have a chance, hopefully, to get first shot at parts from a Silverado 1500 5.3 for a swap.
Beside the obvious items, motor, transmission, wiring harness, pcm, mounts, what else do you think I should try to get? I was thinking the inside cab wiring harness, gauge cluster, exhaust system, and heat/Ac switches.
Is there something I’m missing or included that I don’t need? For example, what sensor should I make sure I get?
It’s for a 72 Burb. I got the heating/Ac stuff for the fire wall back for a 72. I’ll need to get motor mounts from an aftermarket source. I’m not going to get the seats, seat belts or anything like that.
Chances are that this won’t work out… just my luck……. but maybe this tread will be helpful to others besides me.
OhNoJoe is offline   Reply With Quote
Old 04-16-2008, 03:30 PM   #2
Re: What to take from a 2007 Silverado 1500 5.3
I`d keep the`07 truck until everything is done on the Suburban.
Old 04-16-2008, 03:48 PM   #3
OhNoJoe
OhNoJoe's Avatar
THe 07 is being parted out. Hit on the back DS
Old 04-16-2008, 07:20 PM   #4
BustedTruck
BustedTruck's Avatar
Be sure to get the gas pedal & tac module.
BustedTruck is offline   Reply With Quote
Old 04-16-2008, 07:31 PM   #5
The rear axle and disc brakes would be a good thing, well heck the entire brake assembly, front and rear and ABS, would be useful.
Old 04-16-2008, 07:35 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
Is this an 07 classic or NBS? The NBS trucks have AFM, I guess you'd have to have that programmed out?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-17-2008, 03:39 AM   #7
I`m just saying don`t scrap the donor until you have the reciepient running.The part you scrap will be the one you need.I don`t think anyone can just sit here and tell you exactly what you`ll need.
Old 04-17-2008, 04:27 AM   #8
franky69c10
chevy runs deep
franky69c10's Avatar
seats
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 04-17-2008, 06:44 AM   #9
wibilly
wibilly's Avatar
tires and rear end would be all that would interest me
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 04-17-2008, 06:57 AM   #10
shifty
Questionable
shifty's Avatar
in all seriousness? i'll tell you what i tell everyone else: TAKE EVERYTHING YOU CAN.
it is one thousand times better to have leftover parts you don't use than to nickel and dime yoruself to death buying every little sensor, radiator hose, cable, etc.
get the power steering hoses, get the fuse/relay box, get the wiring harness, get all of the peripherals lik A/C compressor and alternator and PS pump, belts, oil pan, bolts, sensors, hell, even the pedal assembly. anything that is in any way connected to that engine to supply water, fuel, fluids, electricity, take it. even take the relays and fuses.
get everything you can - i thought i was getting a lot with all the peripherals, pedals, computer, harness, power steering lines, and rubber hoses....and then wound up spending another $600 or so buying parts at a junkyard.
learn from my mistakes.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-17-2008, 02:35 PM   #11
OhNoJoe
OhNoJoe's Avatar
Shifty as always great advice
Old 04-17-2008, 02:39 PM   #12
'68 C-20
'68 C-20's Avatar
I echo Shifty, if you can store it, take it all. besides with that late model of truck, there are not any in boneyards yet. You can probably get premium price from an other '07 owner if they had a minor incident.
DIY body and paint work is cheap, making it look good... priceless
My Toys;
’26 Ford Model T
‘72 Triumph Spitfire 1500
'09 "The Briggs Flyer" Gettin' High.
'68 C-20 is offline   Reply With Quote
Old 04-17-2008, 04:38 PM   #13
Ackattack
Ackattack's Avatar
If you don't want the seats, send them my way!
Make sure you get the gas pedal and TAC module, those two things are easy to overlook. Also, get the ALDL from inside the cab.
If you're going to be running disks in the back, you might want to think about taking the master cylinder/booster.
Radiator and electric fans wouldn't be bad either.
Ackattack is offline   Reply With Quote
