Old 04-16-2008, 08:06 PM   #1
whatnow123
whatnow123's Avatar
Gas Pedal option?
Hey Everyone!
Is there something out there to replace the gas pedal that mounts on the pivot "balls" on the floor? Something that can be bolted or welded to the existing throttle rod?
Any ideas or pictures of what you have done? Not sure I want to change everything out for a Locar (SP?) type and was wondering if there was something easy and functional to do.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 04-16-2008, 08:20 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Gas Pedal option?
Originally Posted by whatnow123 View Post
Hey Everyone!
The 69 to 72 trucks used a gas pedal similar to the ones in today's vehicles (hangs from the cowl.) If you can get the complete assembly it should be bolt in????????
I believe they used cable instead of a rod through. I have one out of a 72 I'm saving for my truck for "someday." Never gone so far as to see what needs to be done to add it.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-16-2008, 09:14 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
There's a faq on this somewhere. Not too difficult an install...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-16-2008, 09:19 PM   #4
GruntyPants
GruntyPants's Avatar
Here's Putter's procedure from the FAQ.
Great write up!
http://67-72chevytrucks.com/vboard/s...00#post1383300
Shawn
'67 Short Step
'70 Short Wide
Last edited by GruntyPants; 04-16-2008 at 09:21 PM. Reason: Givin' Putter his dues...
GruntyPants is offline   Reply With Quote
Old 04-17-2008, 06:39 PM   #5
1969stepside
1969stepside's Avatar
can i take out the floor mounted pedel on my 69 snd mske it a hanger like on a 72
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 04-17-2008, 07:32 PM   #6
You can adapt the 71 to 87 cable throttle assembly to work on the 67-70 (throttle rod) trucks as referenced in the afore mentioned posts, but you will need to change some things on the intake/carb, as well as have the cable and cable type pedal assembly to make the conversion.
You could alwasy just run without the pedal, but it's not the best way to get rid of the floor mounted pedal.
Old 04-17-2008, 08:07 PM   #7
whatnow123
whatnow123's Avatar
That's the question I was asking.. if something can be done to the existing rod to attached a pedal somehow without changing out the whole assembly.
Build thread:
Old 04-17-2008, 08:57 PM   #8
Ace in the hole
I don't see why not. It may take some experimenting but I think something could be done.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 04-18-2008, 02:17 AM   #9
JimKshortstep4x4
To adapt the 71 style to the 70 and older cabs it is necessary to modify the firewall if changing over the whole setup. On my 69 cab I cut the 69 rod and welded the section of a 71 style rod to it. I left the accelerator rod as it was. Here is a picture of the pedal that I ended up with. The weld area can be seen in the pic.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
