Old 04-17-2008, 04:33 AM   #1
67chevemall
67chevemall's Avatar
350 guys PVC
Does it matter what side your put the PVC plug/valve?
And the breather on the other side....
Can these be switched around or is it set?
might be a dumb ?
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-17-2008, 04:45 AM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: 350 guys PVC
It can be on either side.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-17-2008, 04:47 AM   #3
Blue85
Oilfield Trash
Blue85's Avatar
Re: 350 guys PVC
Dont matter which side it on, ive ran them on both sides with no trouble.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 04-17-2008, 04:50 AM   #4
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: 350 guys PVC
True that. It is after all, just a vent to relieve crankcase pressure, is it not.
Highsteel is offline   Reply With Quote
Old 04-17-2008, 04:54 AM   #5
67chevemall
Re: 350 guys PVC
thanks guys
now I can rest...lol
Old 04-17-2008, 05:22 AM   #6
1tigers
Re: 350 guys PVC
I believe its called a pcv valve.
1tigers is offline   Reply With Quote
Old 04-17-2008, 05:35 AM   #7
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: 350 guys PVC
Positive Crankcase Ventilation
Old 04-17-2008, 06:39 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 350 guys PVC
no dumb questions
Old 04-17-2008, 07:04 AM   #9
jrdv
jrdv's Avatar
Re: 350 guys PVC
What about not running a pcv and just having a breather on each side?
What's the downside?
jrdv is offline   Reply With Quote
Old 04-17-2008, 07:07 AM   #10
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: 350 guys PVC
A PVC valve vents the block into the carburetor and out the exhaust. A breather vents the block into the engine compartment. You choose.
Old 04-17-2008, 03:41 PM   #11
67chevemall
Re: 350 guys PVC
does the carb need the hose going through it to function right?
I'm all for 2 breathers
Old 04-17-2008, 07:02 PM   #12
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: 350 guys PVC
Click this link for a better understanding of what the Positive Crankcase Ventilation system is and what it is used for.
Hope this helps you!
Old 04-17-2008, 10:12 PM   #13
TonyJohnson
TonyJohnson's Avatar
Re: 350 guys PVC
The key word is positive. A breather is a passive vent.
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 04-18-2008, 03:31 AM   #14
Longhorn Man
Re: 350 guys PVC
A good comparison of breathers verses PCV system;
Lest say you have a room filled with smoke, toxic gasses, acid in the air, and oil droplets. On one wall, there is a window, and on the oposite wall, another window.
Open the windows to clear the air in the room.
That's the breather set up.
Place a window fan that spins an insiane RPM and is able suck the room clean in a matter of moments, with fresh air coming in the other window supplying fresh air.
That's the PCV set up.
Old 04-18-2008, 03:43 AM   #15
Rollie396
someday it will be done!
Rollie396's Avatar
Re: 350 guys PVC
I like that description.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 04-18-2008, 03:48 AM   #16
Longhorn Man
Re: 350 guys PVC
Describing it like this would make anyone understand... even my mom, and it would take her 20 min to figure out where to put the oil.
Old 04-18-2008, 03:50 AM   #17
Rollie396
Rollie396's Avatar
Re: 350 guys PVC
exactly.
'80 LWB 2wd beater
my pics
Old 04-18-2008, 05:49 AM   #18
muscletrucks
muscletrucks's Avatar
Re: 350 guys PVC
thanks highsteel for the link
1972 GMC Sierra Grande 3/4 Ton 4x4
1970 Mercury Cougar XR7
1943 Farmall M
muscletrucks is offline   Reply With Quote
Old 04-18-2008, 05:42 PM   #19
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Re: 350 guys PVC
Breathers look cool, but they get oil all over your nice shiny valve covers. If you don't clean it all the time, it runs down to your ex. manifold and makes a stinky, and the ladies don't like the stinky.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 04-18-2008, 06:07 PM   #20
jorgensensc
jorgensensc's Avatar
Re: 350 guys PVC
You almost described positive pressure ventilation in a house or structure fire. Reverse the fan to pushing the smoke (introducing fresh air) and the other window leeting the smoke out and you would have what we use in a structure fire. But for purposes of your explanation I will give you a little artistic flexibility.
SHawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
