Old 04-17-2008, 04:36 AM   #1
67chevemall
67chevemall's Avatar
Tire lbs rating ??????
If a tire says it can handle 1526 lbs does that mean you times it by 2( half the vehicles wieght) and hope the vehicles wieght fits.
Or do you times it by 4 ( all four tires)
Or do I have no fn idea what I'm saying?
Our trucks are around 3500lbs no?
So if it is times 4 that gives me 6000lbs??
help me out here.....
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-17-2008, 04:57 AM   #2
89 crew
Re: Tire lbs rating ??????
You times it by 4. (as long as all 4 tires are the same) The total you come up with is the maximum load the truck can legally carry.
89 crew is offline   Reply With Quote
Old 04-17-2008, 05:01 AM   #3
67chevemall
you rock
thanks
so 4 1526lbs tires are good for
over 6000lbs of truck....
cheers
Old 04-17-2008, 05:11 AM   #4
Yup, but that is truck, passengers, fuel, cargo, etc that goes into the formula.
Palf70Step is online now   Reply With Quote
Old 04-17-2008, 05:20 AM   #5
haysonj
haysonj's Avatar
Just make sure you keep all four tires on the ground
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 04-17-2008, 06:25 AM   #6
89 crew
One other thing. The closer you are to the top weight limit of the tire the faster it will wear, and the easier it will damage.
Old 04-20-2008, 02:45 AM   #7
67chevemall
I like that ****.. great point. Pit Crew Chief stuff...amen
Old 04-20-2008, 03:03 AM   #8
Highsteel
Chasin' the Dream
Highsteel's Avatar
Tire ratings will not change the GVWR(Gross Vehicle Weight Rating). The tag in my 71 C/10 says as manufactured maximum Gross Vehicle Weight 4400 lbs - Maximum Capacity 5400 lbs. (This is the number that you go by to be "Legal")
Buying 10 ply's rated at say 2500 lbs does not mean you can truck on down the road with 10,000 lbs.
It tells me that unless I think I'm gonna get better tire wear its pointless to by a tire thats rated more than say 1500.
Highsteel is offline   Reply With Quote
Old 04-20-2008, 03:07 AM   #9
67chevemall
good stuff man
The tire is 1526lbs I think
after 12 years I think I might have
finally the right Wheel tire for the project.
Old 04-20-2008, 05:03 AM   #10
89 crew
Yes I know it won't raise the gvw on a light truck, but if you put 4 tires rated at 1500 lbs on a truck with a 9900 gvw you legally can't go over 6000 lbs total weight.
