Old 04-17-2008, 05:18 AM   #1
jrdz2120
Need help with my new 72 long bed
I just got a 72 the other day. I ran it about a year and a half ago in my 2000 silverado 5.3 and was neck and neck. My problem is I picked it up cheap running bad. From what I can tell it has a 350, long tube headers, edelbrock performer intake and 750 carb, hei and 700r4. It idles smooth and revs smooth in park, but when in gear it struggles and misses. So far I have installed fresh plugs, wires ,cap, rotor,coil, and fuel filter. What I have found wrong is header collector leak, 12v wire from battery to alt. is melted and ignition switch if jiggled cuts out sometimes and not sure if carb is bad or was swapped out. any help or input will be great. Thanks.
jrdz2120 is offline   Reply With Quote
Old 04-17-2008, 07:35 AM   #2
streetstar
streetstar's Avatar
Re: Need help with my new 72 long bed
welcome to the board ! post a pic when you can
Thats a tough predicament -- it can just feel like you're throwing money at it after awhile
Hopefully someone will chime in
but in the meantime ---- ttt
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 04-17-2008, 07:41 AM   #3
chevychase
chevychase's Avatar
Have you checked the timing?
Joe
chevychase is offline   Reply With Quote
Old 04-17-2008, 03:05 PM   #4
matthufham
how's the choke?
matthufham is offline   Reply With Quote
Old 04-17-2008, 04:02 PM   #5
jrdz2120
It has a manual choke that is not connected and I will check the timming, but not sure of where it is sipposed to be at.
Old 04-20-2008, 01:55 AM   #6
jrdz2120
Ok, so I have changed plugs, wires, cap, rotor coil,fuel pump,and fuel filter.
I checked the timming and it was at 12btc@600 rpm. I set it at 4btc @ 600 rpm and It just started banging out worse. I also re-wired power leads from battery and fuse box to dist. soldered connections and changed ignition switch. All that is left is carb and dist. itself. Any input please? Thanks.
Old 04-20-2008, 04:40 AM   #7
49m
49m's Avatar
My camaro did that and it had a cracked head.
My Rides
1969 Mustang gt coupe
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
2005 Ram 2500 Cummins
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=279831
49m is offline   Reply With Quote
Old 04-20-2008, 05:22 AM   #8
jrdz2120
Do you think so? There is no smoke, overheating , waterleaks and the oil is clean. Thanks.
Old 04-20-2008, 05:23 AM   #9
jhow66
jhow66's Avatar
12*BTDS with hose off and plugged?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-20-2008, 05:29 AM   #10
jrdz2120
Do you think so? There is no smoke, overheating , waterleaks and the oil is clean, but it just misses in gear. Thanks.
Old 04-20-2008, 05:50 AM   #11
jrdz2120
Yes, it was 12*btds with the advance hose disconnected and plugged, but I set it to 4*btdc and started sputtering worse. It feels like an ignition problem, but everything has been changed except the module and dist and carb. Help.
Old 04-20-2008, 05:53 AM   #12
tim21391
tim21391's Avatar
did u say you changed your points?? or is it hei... my truck was up on the highway and i was runnin about 75 or 80 and then all of a sudden i lost power and couldnt go faster then 45 but when i rev in neutral i had all power there..and it missed on takeoff alot too..so i fixed my points and it was fine
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-20-2008, 06:00 AM   #13
jrdz2120
I'm sorry, I have a HEI in the truck.
Old 04-20-2008, 06:24 AM   #14
tim21391
tim21391's Avatar
ok my mistake im sorry
Old 04-20-2008, 06:48 AM   #15
69long"n"low
69long"n"low's Avatar
i was having problems like that before to check yor sparkplugs set timing to 8 degrees and make sure that choke is open all the way if your not using it oh ya and make sure that none of the sparkplug wires are touching anything metal
69long"n"low is offline   Reply With Quote
Old 04-20-2008, 07:35 AM   #16
jhow66
jhow66's Avatar
5 & 7 crossed? Broke plug (outside)?
Old 04-22-2008, 01:50 AM   #17
jrdz2120
Well, I got the truck running today and I still have problems. I changed the dist. out and the number 7 plug was cracked. I set the timming at 8 deg.,idle at 600 and test drove it and It ran like a bat out of hell for about 15 minutes now It feels weak , but doesn't bangout any more. The header gasket at the number 4/6 exhaust ports blew out. Could that cause the problem? HELP PLEASE. Thanks.
Old 04-22-2008, 02:00 AM   #18
jhow66
jhow66's Avatar
No. Dist. moved? (loose)
Old 04-22-2008, 02:48 AM   #19
jrdz2120
I checked the timming and it is still@8deg. btc. Do you think all that heat dumping on the #6/4 plugs could cause it to run weak?
Old 04-22-2008, 06:29 AM   #20
jhow66
jhow66's Avatar
Decribe "weak".
Old 04-22-2008, 06:38 PM   #21
jrdz2120
The truck went from tire smoking instant throttle to running, but not strong as mentioned before in a span of 15/20 minutes.
Old 04-22-2008, 08:19 PM   #22
jhow66
jhow66's Avatar
Check gas filter-try it with gas cap off (vacuum in tank)
Old 04-22-2008, 08:53 PM   #23
jrdz2120
I'll give that a try .I'll also change the gasket at the header and give it another once over.Thanks,
Old 04-23-2008, 03:59 PM   #24
jrdz2120
Had a fouled plug #8. Rund ok ,but now kind of boggs from dead stop launch.
Maybe cap/ rotor fouled?
Old 04-23-2008, 07:10 PM   #25
jhow66
jhow66's Avatar
You need to take it to a buddy that knows carbs. Sounds like a carb adjustment problem. Cap and rotor don,t just "foul".
