Old 04-17-2008, 06:00 AM   #1
69CamperSpecial
69CamperSpecial's Avatar
Question 3/4 ton drum to disc for '69 rear end
Ok from what I have read on here looks like rear discs became standard at some point? What year would that be (if that is correct)?
The plan is swap entire rear-end if I can find one in a junk yard - only other question is are the rear-end the same width - seems like I read that the axles got longer in the 71-72 time frame - assume an inch on either end isn't an issue if I replace the whole thing...
Any issues with drive shaft legth or u-joint size I need to think about?
sorry for the newb questions.
thanks
Ian
previously owned
'64 sb fs
'66 lb fs
Currently owned
'69 Camper Special 3/4 ton 350
'01 Sub 3/4 ton 8.1L
69CamperSpecial is offline   Reply With Quote
