Old 04-17-2008, 08:05 AM   #1
blkboot
Question need help
I lowered my 71 c-10 about a few weeks ago.i drop it 2 in da front and 5 in da back.i lower it without the bed on the truck,and sunday i put my old bed in it just to see how lower it was.it does nt look like it lower it much in the back and thtas what i wanted.my question is with a 5in drop in the back.do i need to chande the shock monts,to make it drop a little moreor what?i looked up under it and look at the bump stop over the rear end and i think i have about a two in gab between the bump stop and the rear end.please help me you guys.some pics will help to.
blkboot is offline   Reply With Quote
Old 04-17-2008, 09:10 AM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: need help
what did you do for your 5 inch drop in the back?
does your truck still have suspension travel when you jump on the bumper? my guess is no, and you're binding on something. did you get shorter shocks too?
IvelDesigns is offline   Reply With Quote
Old 04-17-2008, 03:45 PM   #3
blkboot
Re: need help
i change te springs and yes my truck do have suspension travel
Old 04-18-2008, 06:03 AM   #4
blkboot
Re: need help
Man Nobody Wantt To Help Me
Old 04-18-2008, 07:35 AM   #5
Sammy
Re: need help
I thought ,may be wrong, you should relocate shock mounts because the angle changed anything 4 inches or more in the rear??
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-18-2008, 05:15 PM   #6
steelhorse
steelhorse's Avatar
Re: need help
If you didnt change the shocks the truck may be resting on them.Another thing to comsider is that that drop is from stock hight and if your old springs were worn it may not drop 5 inches from your existing hight.
steelhorse is offline   Reply With Quote
Old 04-18-2008, 05:29 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: need help
You need to have shorter shocks. You also need to use the shock relocators like Early Classic Enterprises sells. The let the angle of the shock change to let it work better, especially helpful on 4-inch lower and more in the back.
From what you wrote, it sounds like you pulled the bed off. If you did, you may not have it back in the same place as you had it before you pulled it off.
The best way to know how much of a drop you get is to measure BEFORE you drop and AFTER you drop to see how much change you end up with.
Member Nr. 2770
Old 04-18-2008, 05:45 PM   #8
cdowns
cdowns's Avatar
Re: need help
like they said shorter shocks shock relocater and also an adjustable panhard bar are required to properly complete the job and have the rear centered
