Old 04-17-2008, 09:00 AM   #1
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Didn't burn down my house or truck...
tonight i got the drivers side door popper installed and functional. first i hardwired it, then i was able to get the remote working.
here's a video of it in action: http://www.youtube.com/v/DgwJOAUwUS4
also, check my build thread for more details.
IvelDesigns is offline   Reply With Quote
Old 04-17-2008, 09:16 AM   #2
berencam
berencam's Avatar
Re: Didn't burn down my house or truck...
coolio, now all you need is a spring loaded hinge, or lambo doors....
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 04-17-2008, 09:19 AM   #3
IvelDesigns
or i could just always park on a hill. then they'll swing open
Old 04-18-2008, 07:14 PM   #4
Brad
Out of the carpool lane.
Brad's Avatar
I looked at your build thread and it didn't seem to show how you hooked them up to work. I mostly just saw holes drilled in your door, etc. Do you have more detailed pics and a writeup of how you made the solenoids and poppers work?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 04-18-2008, 08:36 PM   #5
IvelDesigns
for mounting them, it was actually really simple. the article that i was using as a guide showed that you should drill a hole on the latch lever and run the cable through it. Not sure what kind of steel that is, but i couldn't drill it. I even took it to an auto shop near by and they couldn't either... not even a scratch.
so, i welded a bolt on to it and called it good.
the solenoid is then mounted directly below the latch at the bottom of the door. This way the solenoid pulls straight down and the door pops open.
I did get both doors done yesterday, and got all of the wiring tucked up under the dash. The only thing left is to run a ground wire from the door to the cab so that it will stop sparking when i pop the doors.
Old 04-18-2008, 08:51 PM   #6
Brad
Brad's Avatar
You make it sound very simple and straightforward. I'll be having to do this very soon, but haven't taken a close look and don't have components yet. Got any recommendations? What article did you use as a guide?
Old 04-18-2008, 10:39 PM   #7
IvelDesigns
it was the december 2007 of custom classic trucks i believe. Now that i'm done with it, i could send it to you if you need. It was really helpful regarding the mods needed on the latch, and the mounting location for the solenoid.
It didn't go into any details on the wiring at all, but the diagrams with the kit were really good. I have the kit number at home, and will post it here later tonight.
all in all, it was pretty simple. if i had to do it again, i'm sure i could get it done in a day.
Old 04-20-2008, 07:08 AM   #8
Brad
Brad's Avatar
Thanks man! I'll PM you my addy.
Old 04-20-2008, 09:02 AM   #9
Sammy
Can you copy the article make a file first? I'd like to read it please..I need to know exact location, Thanks
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-20-2008, 09:47 AM   #10
IvelDesigns
copies! what a great idea. i won't be able to send it out until monday anyways, so i'll make you both copies and drop them in the mail. Sammy, PM me your address.
Old 05-02-2008, 01:28 AM   #11
IvelDesigns
copies have been sent to both of you.
good luck with the install!!
