Old 04-17-2008, 05:44 PM   #1
Shon
Wanting to tow with my 71 LB C10
I have a 71 LB C10 that I want to tow my car/trailer with. it has the 350/350 combo and 3.73s.
I am guessing I need either air shocks or air bags to help the suspension and I need a Class IV hitch set up, any recommendations?
Also, the truck is a manual set up with front disc/rear drums, I want to run a brake controller for the trailer, should I convert to a power brake set up? if so, where is a good place to order the stuff from?
Thanks, SH
Shon is offline   Reply With Quote
Old 04-17-2008, 06:27 PM   #2
haysonj
haysonj's Avatar
Re: Wanting to tow with my 71 LB C10
The brake controller is for electric trailer brakes and is not affected by the truck brakes although it would be better to have power brakes when towing takes less foot pressure to apply brakes. Air shocks would help if you have a lot of tongue weight but stiffer springs and anti sway bars are better. I put the Draw-tite hitch on mine it is a direct bolt on application rated at 7500 pounds
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 04-17-2008, 06:31 PM   #3
Shon
Trailer has the electric brakes and I will have a brake controller, i feel safer that way....
any suggestions on teh stiffer springs, like part numbers or companies to start looking into?
Old 04-17-2008, 06:51 PM   #4
chris71
chris71's Avatar
someone told me that the heavy duty springs on the C10 were actually stock C20 rear springs (3/4 ton) i have seem in LMC that they have 3/4 ton heavey duty springs too. if this is the case then you can get stiffer springs through just about any of the major companies or site vendors
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 04-17-2008, 06:59 PM   #5
Shon
I had heard that too.
Old 04-17-2008, 07:03 PM   #6
Shon
Any suggestions as to the hitch I might need:
Draw tite part numbers:
41504 http://www.drawtite-hitches.com/search?q=41504
41903 http://www.drawtite-hitches.com/search?q=41903
75034 http://www.drawtite-hitches.com/search?q=75034
Old 04-17-2008, 08:09 PM   #7
haysonj
haysonj's Avatar
I have the 75034 and it is good up to 5000 lbs my trailer weighs about 1200 and a truck only weighs about 4000 so I see no problem Just make sure you have the 1 inch shank on your ball
Old 04-17-2008, 08:35 PM   #8
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I tow a 16' car trailer about once a year with my '72 1/2-ton two-wheel drive with 350/TH350, 3.08 gears, leaf rear suspension, and front power disks/rear drums. I have a hydraulic brake controller plumbed into the brake lines and electric brakes on one axle of the trailer; this setup works well. The leaf rear suspension needs no extra help.
Your 3.37s will pull better over the hills than my 3.08s.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 04-17-2008, 10:01 PM   #9
chevguy7
chevguy7's Avatar
PO of my truck used to have a camper on it. He had adjustable air shocks on the truck for when he drove with the camper. Do get electric brakes for the trailer.
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs
http://67-72chevytrucks.com/vboard/s...d.php?t=272458
2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds
chevguy7 is offline   Reply With Quote
