Old 04-17-2008, 07:39 PM   #1
1966ponyguy
1966ponyguy's Avatar
Stock Trailing Arms question
Starting cleaning up the parts to get ready to put everything back together last night and noticed that 1 of my trailing arms (68 swb) is coming apart. I guess the arms are 2 stamped pieces. Is this normal or a problem? Looks like a bolt hole in the side of them where a bolt could / should go to help hold them together, but didn't take one out, maybe missing?
1966ponyguy is offline   Reply With Quote
Old 04-17-2008, 09:03 PM   #2
john@thepier
john@thepier's Avatar
Re: Stock Trailing Arms question
There was rivets that held them together not bolts. Darn rust is what ruines them and makes them seperate.
john@thepier is offline   Reply With Quote
Old 04-17-2008, 09:05 PM   #3
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
They have a couple of extra holes not a big deal.
Because of the way they are made rust is a big issue with the trailing arms.
You can take it to a shop and have a plate welded to the top and bottom or box the entire unit if you like.
Or you can always buy a good arm off someone.
The 1/2 ton arms come from the factory with rivets, the 3/4ton are riveted with a reinforcing plate along the bottom
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 04-17-2008, 09:05 PM   #4
Green Machine
Green Machine's Avatar
Pics wuld be handy - If they are coming apart then the welds have likely rusted off. They could be starting to spread apart. Check for rust growing between the two halves, if it is anthing more than minor, I would replace them. There is a set on the parts board for sale right now. Godd used ones aren'treal expensive and are a lot easier to change now when things are apart.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-17-2008, 10:18 PM   #5
1966ponyguy
This one is not coming apart, it is in 2 pieces. But talk about timing, just saw the post by Ram man on his home fab trailing arms, looks like I need to stop by the steel shop.
