Old 04-18-2008, 01:43 AM   #1
creeldaddy
creeldaddy's Avatar
sm 465 trans
i have a sm 465 trans at least that is what i was told is in it if you guys can take a look and make for shure and also if you know witch of the items that are circled is the switch for the backup lights if anyone knows thanks
creeldaddy is offline   Reply With Quote
Old 04-18-2008, 01:46 AM   #2
jamie72
jamie72's Avatar
Re: sm 465 trans
yellow is vent
green is back up switch
blue a top fill plug???
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 04-18-2008, 01:51 AM   #3
creeldaddy
creeldaddy's Avatar
Re: sm 465 trans
hey thanks alot
Old 04-18-2008, 02:07 AM   #4
oldsmobilekindofguy
Re: sm 465 trans
yup, that is definatly a sm465 but I do know there are two different styles and the only difference is the number of splines, take the number off of the trans and type it in on google that is what I did with mine and one of the links tells you everything about the two differnet styles and the gear ratios
1967 c-10 longbox project, check it out in projects
1969 c-10 parts pickup, twisted frame
Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block
oldsmobilekindofguy is offline   Reply With Quote
Old 04-18-2008, 03:13 AM   #5
Ace in the hole
Re: sm 465 trans
you have the two wheel drive version. the yoke on the back says it all. The 4x4 version goes right into an adapter for the x-fer case.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 04-18-2008, 03:31 AM   #6
1969 GMC
1969 GMC's Avatar
Re: sm 465 trans
there are actually 3 different versions of the sm465 as far as output shafts go, the 2wd pictured above has 35 splines and a yoke on the output. Early 4wd models have a shorty 10 spline output, and late model 4wd have a long 32 spline shaft.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
