Reverse went out in my transmission the other day! It's a 3 speed saginaw... I was backing up then went to pull out of the spot and it didn't go. That is no fun... OH MY. I have found one local for pretty cheap, i am pretty certain and think that I am going to go get it tom. And try and get it in the truck... We will see.
![]() ![]() 400sb-350 crank 400 destroker!!! 377 2.02 dart pro1 alum.heads msd, holley db hooker pro-comps-3in exh. 3 spd. saginaw-3.73posi Flat Bed...want Reg bed...trades? |
![]() ![]() Join Date: Jul 2002
Re: My Trans Blew UP!!!
Good luck with the replacement.
![]() Join Date: Nov 2004
YEARS ago I got mine stuck in mud... tried to rock it back and forth, almost had it out in Reverse... then BAM! Reverse blew and took 1st gear with it.
Good luck on the replacement. ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
![]() Join Date: Aug 2005
Is it a 3 on the tree or has it been moved to the floor? I had a floor kit in mine and lost reverse on it. Turns out it was the shift linkage and not the trans at all...
![]() Join Date: Dec 2006
For sure check the linkage.
You have a pretty nice set-up there,why not get a 4spd (non-truck) in there? If you are staying with a 3-spd,make sure it's the heavy duty one that came on all 4wd trucks and 2wd trucks with 350 or 396 engine option.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
I don't have the monies for a better trans...
![]() What was wrong with it was that The shaft that holds the reverse idoler(sp) broke in half where the clip goes, and the cast-iron that holds it broke. I am in the process of getting the new one in. I have to get the clutch aligned back up... hoping that i dont have to pull the bell housing and the clutch plate to get it back together. Then after that hope the trans will slide in, then bolt it back in. Its been converted to a floor shifter, I knew it was not the likage. I have pics I will post when I have time. I have to work this weekend. I will proablally get it back Monday. I work this weekend, in the ER, 12hrs shift. So probally not after work.
HERE.......Somewhere
How do you blow one up?
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 ![]() ![]() Classics make it possible! |
I was backing up. I may have over goosed it, not sure. Then when I backed up again, it wouldn't go. I took the side cover off and saw the busted shaft for the reverse idoler.
Last night I managed to get the clutch aligned and got the bushing back into the crank. Then I managed to get the trans back in and alighned back in place, amazingly. I was so stinkin happy! Then I got the bolts back in, even better! So happy! Today I am back at work. Hopefully today my wife will be able to get the new transmission mount for me today... Then I can get the cross member back on and the drive shaft then I am good!!!
Well Satuday my wife got the wrong one, I took the old one off and sent her back up there with the old one. She got the right one!
Congrats on being mobile again!
awesome. and it sounds like a prety cheap fix!
