Old 04-18-2008, 06:33 AM   #1
billsbowtie
billsbowtie's Avatar
3 on the tree shifter rods & z-bar frame bracket f/s
shifter rods $25.00 picked up or $35.00 shipped. someone ask me for some of these a while back i hope he sees this tread because i forgot who it was.
the frame z-bar bracket $20.00 shipped.
i have 67/72 chevy truck parts f/s.
billsbowtie is offline   Reply With Quote
Old 04-19-2008, 06:43 AM   #2
billsbowtie
Re: 3 on the tree shifter rods & z-bar frame bracket f/s
$18.00 shipped on the z-bar bracket.
Old 04-19-2008, 04:27 PM   #3
Mt Man Chad
Mt Man Chad's Avatar
Bill do you have any extra shifter rod bushing. (Large inside diameter) like the one shown on the left???
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 04-20-2008, 12:25 AM   #4
billsbowtie
chad i don't have any extras.
Old 04-22-2008, 02:45 AM   #5
billsbowtie
$30.00 shipped on the rods & $15.00 shipped on the frame bracket.
Old 05-02-2008, 01:55 AM   #6
therealcurtis
is this the z-bar for the clutch or did the shift linkage have a z-bar, or bell-crank, or whatever you want to call it?
68 Chevy LWB stepside (currently hauling $#!* out of my backyard)
94 CVPI R.I.P. was fun until the tranny died, and the brake line rusted thru and the dashboard lights were blinking codes at me.
93 Exploder
09 Scion XB
01 Indian Scout
therealcurtis is offline   Reply With Quote
Old 05-03-2008, 03:07 AM   #7
billsbowtie
the realcurtis these are just the shifter rods. i have the z-bar and rod and the part that goes over to the block for $25.00 plus ride.
Old 05-04-2008, 12:10 AM   #8
therealcurtis
I need everything from the tranny to the collum, including the lever inside the truck. I want to go from an aftermarket floor shifter back to the stock setup that the PO ripped out.
93 Exploder
09 Scion XB
01 Indian Scout
Old 05-04-2008, 04:34 AM   #9
billsbowtie
is your colum still good? i think i have everything to change it back i will check tomarrow.
Old 05-04-2008, 04:45 AM   #10
Don Brace
Active Member
I bought the 3 speed column from you a while back and will take the shift rods. Send me a PM and I will mail the $35.00.
Don
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
61 Impala CVRT 409 4 SP
2- 71 Longhorns
Always looking for old toy trains, Juke boxes Pin ball and game machines.
Don Brace is offline   Reply With Quote
Old 05-05-2008, 04:31 AM   #11
therealcurtis
i think my colum is o.k., not sure how to tell. the spring has some tension and the bushing for the shifter dosen't look too worn.
93 Exploder
09 Scion XB
01 Indian Scout
Old 05-05-2008, 04:54 AM   #12
billsbowtie
i am in the process of moving and over the next few weeks i will be moving all my parts also. i will keep at eye out for the parts you need you do have a six cyl. right. i am not sure if there is a drifference but the last 2 3 on the tree trucks i took apart were 6 cyl. if you need the parts sooner someone else may see this and be able to help you faster .bill
Old 05-08-2008, 04:21 AM   #13
therealcurtis
my truck has a 327 v-8, are they different because on a v-8 the rod would need to clear the valve cover or exaust or something. I think the bell housings were the same.
93 Exploder
09 Scion XB
01 Indian Scout
Old 05-08-2008, 05:13 AM   #14
billsbowtie
i am not sure maybe someone will see this that knows.
Old 05-16-2008, 12:41 AM   #15
Don Brace
Active Member
Parts arrived today. Just what I needed.
Don
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
2- 71 Longhorns
Old 05-16-2008, 05:02 AM   #16
71shortwide
71shortwide's Avatar
You wouldnt happen to have every thing from the clutch petal to clutch fork would you ? thanks
Justin
71shortwide is offline   Reply With Quote
Old 05-17-2008, 02:47 AM   #17
billsbowtie
justin i am not sure there is a drifference but do you need it for a 6cyl. or v-8 ?bill
Old 05-17-2008, 02:49 AM   #18
billsbowtie
therealcurtis have you found the parts you need yet?
Old 05-17-2008, 04:41 AM   #19
71shortwide
its a 6 but i think there the same thanks!
Justin
Old 05-18-2008, 08:47 PM   #20
therealcurtis
No, I havent found them yet, but i'm not in much of a hurry since i got the floor shifter adjusted I can drive the truck now but have no idea how fast I'm goingsince the shifter sits directly in front of the speedo cable connection on the tranny
93 Exploder
09 Scion XB
01 Indian Scout
Old 05-20-2008, 05:26 AM   #21
Conroe trucker
SWBs: 67 2x4, 67 4x4, 70 4x4
I have a 67 6 cyl with a 3 spd nonsynchro first gear. It has the small side cover.
I have replaced it with a 3 spd synchro first gear. It has the big side cover. Actually it is a 3spd OD, but that does not matter for this.
My issue is, do you know if the shift linkage from the column to the shifter shaft link is the same?
The shifter shaft link is different, the nonsynchro has a much longer shaft than the synchro, so I now need the synchro's shift linkage.
I am looking for inlightenment.
Pictures are available if you need them.
Thanks,
Massingill
FINISHED Project thread: 67 SWB 4x4
FINISHED Project thread: 67 SWB 6 cyl cruiser
Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT
01 C5 convertable
08 Z06
Conroe trucker is offline   Reply With Quote
Old 05-22-2008, 05:33 AM   #22
Mt Man Chad
I'm interested if they are still for sale..... I just need to confirm the difference between 6 cylinder and V8's. I have a set and they are about 2 inches short of the the steering shaft. I'll post pics and dimensions tomorrow!
Old 05-23-2008, 04:07 PM   #23
"NOTICE"
Bill`s computer is messed up and he`ll be back by next week.
Old 05-24-2008, 11:18 PM   #24
billsbowtie
these shifter rods are sold. i have some more somewhere but it will be a while before i can dig them out. i still have some z-bars and clutch rods f/s.
Old 05-26-2008, 04:54 AM   #25
therealcurtis
BTW... saw in another post from mt man chad that v-8 vs. I-6 rods are different, 6cyl. rods are a couple inches longer. thought you might like to know.
93 Exploder
09 Scion XB
01 Indian Scout
