Old 04-18-2008, 11:07 AM   #1
RamAirZ
Body lift question, 67?
OK, this is probably a dumb question but I'm looking to do a 1in body lift on my truck, it's a 67' 4wd long bed. I see the part #'s for the urethane body bushings are the same for 67-72 but the body lift kits show a range of 69-72. Is there something I should know here? Can I purchase a 1in body lift and slap it on?
1967 Chevy K10- 4WD project in the works -sold
1985 Suburban- 1/2 ton w/ 3/4 ton gear, 350/700R4 33's and big!
1987 Iroc- LS1/T56 conversion- sold
RamAirZ is offline   Reply With Quote
Old 04-18-2008, 05:33 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Body lift question, 67?
iirc I believe the 67' used a different coresupport bushing then the later models.
sneakysnake is offline   Reply With Quote
Old 04-18-2008, 09:09 PM   #3
RamAirZ
hhmmm but I wouldn't think thath would effect the body lift too much. I'm probably just going to purchase it and see lol
Old 04-18-2008, 09:57 PM   #4
jd4300fel
jd4300fel's Avatar
When I was in to four wheeling jeeps the common practice for a 1inch lift was to use hockey pucks as a spacer. I never did this but thought long and hard about it.
Mike K
Friend of Bill W
jd4300fel is offline   Reply With Quote
Old 04-19-2008, 03:16 PM   #5
1969K10
1969K10's Avatar
they don't recommend that anymore
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 04-19-2008, 04:00 PM   #6
sneakysnake
Something I just ran across might help
http://67-72chevytrucks.com/vboard/s...d.php?t=288154
