04-18-2008, 07:02 PM | #1 |
Living In The Past
Sun Visors
Probably dumb, but is there a trick to removing the metal rod they pivot on? I tried pulling that rod out and could not budge it. If I pull any harder I may damage something.
04-19-2008, 12:23 AM | #2 |
Re: Sun Visors
Mine pulled right out, with some good tugging. But I had new visors and wasn't worried about anything other than the rod coming out. Just twist, twist, twist, and pull like a sum....cth.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
