PVC Valve for gas tank vent?
Hi,
I'm having trouble finding a suitable vent for my under bed tank and was thinking a PVC valve could work since it's a one way valve. Will this work or are there better options that I just don't know about?
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
Re: PVC Valve for gas tank vent?
Why do you need a valve? Why not a hose with a loop in it?
trailers are for boats |
I think I'd rather have a 1 way valve of some sort. I'd rather not have fuel leaking out of the tank incase it filps for some reasons, which is the main reason I moved it out of the cab.
That's actually a good idea, the PSC fuel cell in my Jeep has the same type of mechanism inside the cell for the vent connection.
I don't see why it wouldn't work..... I don't know of anything else to use, I'll talk to some off-road guys and see what or if they use anything.
R.I.P. Scott Kalitta
I hve used a power brake booster check valve for this . Available at most parts stores
1970 Daily Driver
I have used small metal fuel filters. The ones that is you blow through it backwards it flaps shut.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
![]() Join Date: Mar 2008
Actually a PVC valve is a great choice. It is rated for use with oil/fuel.
![]() ![]() ![]() 1972 GMC Sierra Grande 3/4 Ton 4x4 1970 Mercury Cougar XR7 1943 Farmall M |
