Wiring question
I'm putting a tach in my 60 and I'm siting here looking at a wiring diagram in the shop manual trying to figure out which wire (coming out of the light switch) I need to tap into to get the light in the tach to turn on when I turn on the headlights. If I'm reading the wiring diagram right (fat chance of that!) I can tap into the light green wire and have a light in the tach when I turn on the headlights. Am I correct? Or is there another wire I should tap into? Thanks.
http://public.fotki.com/fuelpump |
Re: Wiring question
No. Tap into any Light Gray wire you see.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Cantankerous Geezer
Re: Wiring question
Here's a link to a wiring diagram from a 60 Chevy car. Basic wiring should be the same for a pickup.
http://chevy.tocmp.com/electrical/wiring/pdf/60car.pdf It shows the wire from the fuse block to the panel lights as grey. This would be the wire to tap into. If there is a place on your fuseblock labeled panel lights, it's the ideal place, but I can't recall if there is. You do not want to tap into the wiring from the headlight switch, it is not fuse protected.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
